I was thinking about getting a Precision PT6262 for my RB26/30, have had a look on eBay $1137.28 delivered and Powertune Australia looks to have dropped their prices to$1150, only $13 difference so i ordered through Powertune Australia as they have warranty for the turbos as well as the support! I am excited and can't wait to test this baby out!! :)
sounds about right, powertune quoted me for 6266 jb $1080
Finally got my 6466 .82 twin scroll running on a RB25/30 - beautiful response down low and its well on boost by 4000 rpm if not earlier,
Currently making 308rwkw at 13psi - low boost as the engine is still being run in.
That's good to hear! What's the maximum psi you plan on running on pump gas with that 6466?
Also, can you please do me a personal favor and measure the exterior diameter/width of your housings? I'm just worried I may not be able to fit it in my engine bay as my current setup is already a tight fit. Here's what my engine bay looks like:
wow 86 pages now? this thread is popular!.
got some results from my build for yaz.
431 hp atw @ 16psi on the little 6262 t4 t/s .84 on pump with plenty more left in it. will update the dyno charts section with my dyno sheet when I can be f*kt, or after I go back for the second tune.
Well, curiosity got the better of me after I encountered an issue with my 6466. I removed the unit, removed the drain and inlet oil restrict or and had a peek inside. Seems the entire rotating assembly is shifting forwards and backwards inside of the cartridge housing, almost as is there is a retaining clip missing. So on the blower I get, and it seems they don't really seem too keen on warranting it as I removed the restrictor. The fcuk? I wasn't born yesterday! I'll. upload a vid of it soon. I hope precision comes to the party on this one, same goes for PT.
I'm still debating whether to go with 6262, 6266 or 6466 as I'm planning to run this on 98 octane pump gas no more. I was told by a vendor the spool difference between a 6266 and a 6466 is almost negligible.
Yeah I can measure it up for you PM me to remind me if I forget!
I had the same dilemma I spoke to precision directly and workshops in the US that dealt with them and they all pretty much said about 300-500rpm difference in each so I bit the bullet and went the bigger as I knew id always be curious if I didnt. I haven't looked back put it that way, although I have it in twin scroll on a 6 boost manifold to help it all along and its on a 3L
Should be mid 20s on pump and 30+psi on E85 for the get farrked boost setting
  • Like 1
the 6466 is much bigger than a 3540 .7 front if that helps
Thanks for your feedback Donut_king! It looks like I'll be going with a 6266. The 6466 seems like it would require a lot of boost to come alive and that is no fun mated when it comes to pump gas.
Edited by G37Sam
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
