2 minutes ago, r32-25t said:
You know how you all said the ultimate set up would be the 3.2 with the 6870 and vcam that Jez Tuned. That was reapers car and I’ll let him tell the rest of the story if he wants to
Rightly or wrongly, back when he had talked about that I was definitely pro VCam/6870 for what he said he wanted at the time.
7 minutes ago, r32-25t said:
Cylinder pressures cracking the deck of the block, head studs are to strong to stretch so the deck gives way instead
Ahh I see.  And you think that the same cylinder pressures would not crack the block if there was a non-vcam head ?
The vcam makes more cylinder pressure lower down in the rev range as it’s coming onto boost and that’s what I believe is creating the problem. I’m not willing to experiment and find out on a $13,000 block
1 minute ago, r32-25t said:
The vcam makes more cylinder pressure lower down in the rev range as it’s coming onto boost and that’s what I believe is creating the problem. I’m not willing to experiment and find out on a 13,000 block
I'm bringing up  a couple points not to be a dick, or even defend the fact I've suggested that this kind of combo is good - just like to investigate things which have either turned out well or not... it kinda helps both understand what is working and why to help all of us get better results.  With the info you've presented so far I feel like blaming VCam is a mistake, especially if you have it and you're looking at spending money at moving away from it when its probably not the cause - at least all by itself.
Peak cylinder pressures happen when the intake and exhaust valves are closed, some time after the spark event happens.  There is absolutely zero influence that valve timing has on this all by itself.   The cylinder pressures are going to be everything to do with the compression ratio, how much air/fuel combo has been forced into the cylinder, when the spark has been lit and how stable the combustion process is after that point.   It is VERY possible with a given static cam head setup to exceed the cylinder pressures achieved using a variable cam head setup.
Not doubt Vcam (and the turbo setup used) could be making it easier to create a situation where cylinder pressures get to a point the block can't hold it - but blaming vcam for a cracked block is a bit like blaming a Porsche GT3 for being too fast if you don't brake for a corner and throw one off the road.   Things that improve torque naturally have the ability to put more stress on the parts which have to hold the associated forces, its up to the builder to ensure things are best setup to ensure the best chance of sustaining those forces and in this metaphor - the tuner/owner have to decide where to draw a line in terms of how far its pushed so they have less chance of overcooking the combination you have.
By all means remove vcam if it makes you feel better, but it won't necessarily lose you the ability of cracking the block due to excessive cylinder pressures if you were pushing things hard enough to achieve that.   There may be other reasons you are looking at changing as well, but realistically - if the only reason is due to cylinder pressures then perhaps it should be considered to hold back torque where you think it has caused a problem and keep the nice responsive drive that VCam provides while not compromising reliability.    Modern ECUs/control systems make it not particularly hard to target the torque you want, so instead of building the car to be inherently laggier in all situations it is possible to have your cake and eat it too.
  • Like 2
It’s the same theory as the barra and evo guys who keep the boost low through the bottom and mid range and ramp it in up high to save the rods from bending, just in an rb the rods aren’t the week point it’s the deck or the big ends that let go
Snap, pretty much what I was getting at with my above post - just a bit confused about why you're blaming vcam instead of blaming the boost target/ignition timing which have far more direct influence on the kind of failure you're talking about
  • Like 1
By using vcam you are increasing power and torque which is filling the cylinder more and creating more pressure lower in the rev range which seems to where shit happens
The effect vcam has on power and torque is negligible compared to the boost targeting and ignition timing.  It may make it easier to hit the high torque levels earlier, but you are not obliged to make use of that.   There are MASSIVE amounts of setups running around which would be capable of doing this kind of thing with variable valve timing which are perfectly reliable.  I feel like going to laggier/less streetable setup to avoid cracking blocks when all you have to do is exercise some restraint where it could be a risk is very very strange, though I could be missing something.
Should be going back to 0 degree advance as soon as you're coming onto boost, keeping it on after that is what is causing the issue.
When I tunes SR20s, I do exactly that, use VCT to only get the turbo to come on, and turn it off quick smart.
I've seen plenty of tunes from "workshops" that keep VCT into 6 to 7k RPM, sure you're making much more torque, but can't imagine what cylinder pressures are like.
I'm not sure all the rationale or limits you are considering here, but just to pluck a random number out of the blue - what is the difference on the bottom end between making 500nm at 6500rpm with VCT on, or 500nm at 6500rpm with VCT off but running more boost?
Edited by Lithium
Sorry my response wasn't detailed enough - hence the confusion.
if both were to make 500nm at 6500 with VCT on of VCT off you would assume the motor making 500nm with VCT on would have much greater cylinder pressures.
If VCT were to be turned off for motor making 500nm with VCT on, you'll get a reduced amount of torque also a reduced amount of cylinder pressure.
Motor with VCT off making 500nm, if VCT were to be turned on, you would "assume" that motor would make even more torque, i.e. 500nm+ but now with added cylinder pressure.
Where does the extra cylinder pressure come from, and why are we seeing no more torque as a result of it?
Motor 1 could be a S15 motor
Motor 2 could be a S13 motor
both might be the same, but in reality they're not
Wut.
I'll try one last time, but I feel like I'm being trolled or something.
OK, so lets assume this.
A "workshop" has tuned an S15 which still has VCT on and with the current tune is making 500nm at 6500rpm at the given boost level.  Timing/fuelling is optimised, but because of silly old "workshop" using VCT it throws its insides out.
The engine is rebuilt to EXACTLY the same specs it was prior to throwing it's insides out.  Lets assume that its identical in every way, pretty much as though Dose Pipe went back in time and pushed "workshop" tuner out of the drivers seat and did the tune instead.
This time the engine is tuned with VCT off at 6500rpm, timing/fuelling is optimised for the conditions, but is running an appropriately different boost level to continue to make 500nm of torque at those rpm.
Are you saying the identical engine which is Dose Pipe tuned is more likely to survive?
  • Like 1
I would dare say motor with more boost thrown at it with the intake cam not advanced, i.e. VCT off at 6500rpm will survive vs. motor with less boost and VCT on at 6500rpm making the same 500nm at 6500rpm.
DYOR, this is not tuning advice.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
