Hey guys, if it helps, I've fitted BC's to a bunch of cars at work now. I've got customers in Soarers, Skylines, Silvias and Subarus that I've fitted BC's to and all are doing very well. All customers are happy with the BC's, great product.
I'll be fitting them to my own Skyline in the not too distant future also.
Anyone interested in buying some Tein type HA jap spec coilovers out of my R33?
  • 2 months later...
Are these BC's Kidney Bashers as the Jap ones in my GTR now are killing me on every bump and the Left rear has a Bad Bang in it so they are Fooked.
Thinking of getting a set of these, mainly do Around Town driving and a bit of Highway on occasions... Are they easy to live with in normal conditions???
Cheers Dave
No issues with mine, have been running them in my stagea daily for 9 months.
I have fairly soft springs fitted, almost stock rates, but the dampening is set firm. They feel great on the road, well worth the money.
As with any coilover it depends on what spring rate you get. You probably want 4fr/3rr or 6fr/4rr for a decent ride.
Has anyone used these coilovers on the track? I am thinking of getting these for track days so I am interested to see what peoples thoughts are for these proposes.
I got a set of the BC ER's (external reservoir) made up for my R32 GTR that see's the track regularly. The standard rates they come with are 12kg front and 10kg rear which I think is way too hard. After liaising with Just Jap, i got the factory to produce a set with 8kg front and 6kg rear. They also revalved them for these spring rates and extended the lengths to ensure they would run at the heights i wanted.
I couldnt be happier with them. On the road i have compression and rebound set to full soft and on the track i have found that about the midpoint on both compression and rebound gives me the best feel. Coupled with the whiteline swaybars front and rear, the car is very neutral now whereas it used to be very understeer dominant. Ive cut my times down at lakeside substantially with these coilovers (and with the swaybars).
I couldnt be more happy with the service from Darron at Just Jap either. I was really impressed with the running around he did for me and the quick response time. I fully recommend these to anyone who are after a good track coilover without compromising too much on the street.
Cool looks like they hold up really well. I've been doing some research on them and there is a lot of good reviews through the other forums. Did it cost more to change the spring rates? If you don't mind how much did it all cost with swaybars as well? I am looking at doing the same thing if I go ahead and buy the BC's. PM me if you like. Cheers
The custom spring rates and setup were the same price which I thought was pretty amazing. There was a lot of extra effort put in to get them made up and at no extra charge to me! I got the swaybars through a seller on here or nissansilvia i think, they are Whiteline adjustable products and were around 210 each from memory.
This is what I was after, My Jap Ohlins that came with the car when I got it are terrible.... Lose my breath on some bumps!
Just ordered with JJ so we will see soon!!!!
Go for it, i went from Tein HAs that were in need of a bit of a rebuild and left my kidney on the side of the road to BC BR series and WOW!! so much nicer to drive my GTR as a daily now
Is it really worth going the ext resovoir BC's or is that just overkill for a daily/occasioanl track use?
If its mainly a streeter, just go the BR series mate. The ER's are great, but are more track oriented (harder). If i was choosing some for a daily, i would be going possibly the BR's with 6kg front, 4kg rear as a max spring rate combo
I went for the 8kg Front and 6kg Rear as per the site and it seem good for the short drive I did today after install.
Compared to what I had in there they are like silk..LOL
Just need to set my heights back to where they were and play with the dampening a little bit.
Edited by Turbo Dave
see i was thinking the same going BR's
iv currently got bilstien's on my gtr, and my rear left knocks like a motherf*ker, but bilstiens are an alright brand, so im thinking of jus overhauling them at pedders or somthing.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
