http://www.performancecar.co.nz/news-5900/...-vy-nzpc-146-04
2004 Holden Commodore (VY)
Engine: Nissan RB26DET 2.6-litre DOHC 24V, factory internals, factory cylinder head, Master Power T-60 turbocharger, Trust air filter, 4-inch silicone intake hose, 600×300x80mm intercooler with custom GT-R end tanks, GReddy Type R blow-off valve, Tial 44mm wastegate, Bosch Motorsport 044 fuel pump, custom surge tank, NGK Iridium spark plugs, custom steam-tube headers, custom 3-inch downpipe, 3.5-inch exhaust, Trust mufflers, 50mm custom alloy radiator, twin electric fans, 32-row oil cooler, Link G4 Xtreme engine management system, custom wiring, custom oil catch can, remote oil filter
Driveline: R33 GT-R gearbox modified to rear-wheel drive, Xtreme Drift Clutch triple-plate carbon clutch, 3.9:1 HSV differential, Harrop rear housing, modified driveshaft
Suspension/Brakes: Modified Tein Super Street suspension, Tein springs, Whiteline swaybars and links, Nolathane bushes, factory brakes, uprated pads
Wheels/Tyres: 18×9.5-inch TSW Beyern 5 wheels, 265/35R18 Dunlop Direzza DZ101 tyres
Exterior: VZ Clubsport R8 bodykit, full black respray, custom Brown Brothas graphics/custom Mad Mike/CRE8GRAFX graphics, Ganador-style mirrors
Interior: Buddy Club P1 Limited Edition bucket seats, Willans harnesses, Momo Drift deep-dish steering wheel, Momo GT-R gear knob, Tein EDFC controller, D2 hydraulic handbrake, custom 8-point rollcage, DisplayLink dash
Performance: Dyno Power – 350kW @ wheels (15psi boost)
https://www.sau.com.au/forums/topic/319404-pretty-cool-rb26-conversion/
holdens 4wd system in the adventra wasnt the best i dont think.....
It does seem a bit strange they would do that, but I guess the RB probably delivers the power smoother rather then all in on burst... Must be better for drifting if theyve spent the money to do it?
I doubt it. Wouldn't a drifter be after the most torque possible? a turboed LS1 would produce some epic torque for 2k rpm rather than 5k+ like the 26. Probably did it just to show it can be done...
yeh im not sure, they use monaros in drift with v8s still in them. The only logical reason i thought would be for the extra revs and perhaps the RB being a bit lighter? i dunno
Perhaps its easier to control higher revs then to control all that torque lower down. Havent drifted V8s so no idea on the downfalls of it
its just cool to be different. whether you like 'shittadores' or not, seing one on lock, rb26 screaming at 9000rpm, gate wide open, is wwaaayyyyy cooler than another s13. even a turbo v8 wouldnt have the same appeal if you were a spectator and saw it out on the track...
for me, it would still be cool if it were a v8, but if i heard that thing in the flesh i'd probly be running to the pits to get a closer look
Edited by VB-
bingo.
I was going to be at that event, but got shipped out from Singapore a few weeks ago. I will enjoy working in Singapore more when they open their motorsport complex next year. Drift is popular, and pretty cool that some Aussie influence is present in their drift scene!
thats fanga dan from nz. he has been drifting a rb26 power commo for a while now. kills it too. he wanted to use the v8 but had a 26 or somthing along those lines and could not get enough sponsership at the time to do the v8 thing. combo seems to work very well.
i wonder if anyone has taken the adventra running gear and put it in a commodore shell, turbo/supercharged 4wd V8 power
yep theres a guy on the commodore forum thats doin it. just for the record holden made a ltd edition monaro with the awd. its called a coupe4. the dude from HPF put a big ass turbo on a coupe4. i cant remember how it went.
All I can think is. Why would you bother? Some people honestly just have too much money.
i would be proud to have that parked in my driveway, i reckon the stance, the graphics even the rear wing look agressive yet sleek... regardless of engine type.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
