Hey guys i have a random question that i was thinking about today as i passed one. Those guys that sit in there crv's etc with the cameras at the front on the side of the road...are you allowed to park infront of them? i was told by a friend that someone he knows used have them always on his grass, and one day he cracked it and parked infront of him, and the guy got out and said im going to call the cops and he did, then he coped a fine and his lawyer said his allowed to park there. can anyone verify this? thanks
https://www.sau.com.au/forums/topic/323291-on-the-footpath-cop-cameras/
Yer I think they tend to park in places that aren't real close to driveways so that you have no excuse to park in front of it...I don't see why they can't move if you want to park there anyway. But it is interfering with a law enforcing process, blah blah just like flashing your lights at other drivers to warn them of a camera car.
Lol I know of people that did that. He got told to leave. Locked the car and left. Whereis the law saying that you cannot park infront of them? That's ofcourse if your not violating a parking sign.
All I do is honk when I drive by them because they are sleeping most of the time lol what a job
You can't park on Nature strip but if you were to park legally on road just down from it blocking the view of the laser/camera I don't see any problem with that. If I was called I would tell the speed operator to move as other person doing nothing wrong.
I personally HATE the fact that these fines are issued in Victoria Police name as we have nothing to do with them. They are run/operated by private contractor company.
But I thought they were employed by the 5-0? Isn't that how it works? They do the work and get a piece of the action?
thanks for that mate. now i kno for when i see one outside my house :D
I was aware that those operators aren't police officers but being run by private contractors? I didn't expect that. So this is similar to the hoon hotline as I'm told that isn't run by vic pol or any government section either? So if they aren't employed by the state then where would they get the power to fine people for parking in front of them, etc when you are on public roads/property?
As for passing them I always make sure to flip the bird at them
They are contracted (Tenix), this is from the Gov't. Not Police.
You can park infront of them. I've done it before.
Dude was hella pissed as I'd just watched him setup - serves him right really.
Just bowl the camera over with a mower :sick:
Graeme, what about the situation where the mobile speed camera car is illegally parked on a nature strip? I see it all the time on Queens Rd, so just wondering if you can possibly contest the fine because the car was illegally parked?
i've always been told this.
if we are not legally allowed to park on the grass, cause its council land, but when they park there you allowed to fight the ticket cause they were parked illegally in the first place.
just what i've been told, but never really looked into it.
but i know of people who got fined for parking on the nature strip outside their house.
The camera operators have special dispensation from council by-laws affecting parking on nature strips, ie. they are allowed to.
It's perfectly legal to park in front of one, so long as you are legally parked. If there is no visible signage there telling you it is illegal to park, then it's perfectly legal (so long as it doesn't fall under any of the other rules such as distances from intersections and so on).
Technically you are not meant to know that the camera is there anyway, so how can you know to not park in front of it?
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
