hey guys,
trying to sort out this issue im having with the idle in my car. just some specs on the motor
r34 gtt
exhaust port+match rb26 head
fully forged rb30 bottom end
gt35 .82
vband straight pipe 3.5" exhaust
1000cc inj
OEM rb26 plenum + tbs
OEM rb26 cams
PFC D jetro ecu
while in motion at any speed if i clutch in the revs go up to ~2000rpm and sit there until the car comes to a stop where it will drop down to around ~1700rpm. sometimes it will bounce around from ~1000rpm to ~2000rpm, somtimes will just sit at 2300rpm.
occasionally when i start the car on a cold day/night it will idle nice at 1000-1200rpm but as soon as the car gets moving and i eventually have to stop and clutch in, the above scenario starts.
im spoken to my tuner and he seems to have tried a few things like playing around with the idle control valve (not sure on specifics) but has had no success. his mentioned something about it being 3L and the amount of air the motor flows is so high, its causing problems.
i see 800hp cars idle nice and fine so why cant i? i dont know much about the tuning side of it and was wondering what can be done about it? i should mention that i had no issues what so ever when i ran a single plazmaman plenum + 80mm tb when i had a rb25 in the car.
any help much appreciated guys! i look like a completely idiot at the lights with such a high idle :)
https://www.sau.com.au/forums/topic/323850-high-idle/
do you have any vaccume leaks? they can cause a high idle with a MAP ecu. if not have you tried taking the idle control valve off and cleaning the carbon/oil out of it?
does it only idle funny when cold? or it still has a high idle when at operating temp?
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5277974
it idles high all the time.
only sometimes when the motor is cold it idles lower but only sometimes, but as soon as i start driving it starts idling high again.
i highly doubt i have any vacuum leaks because i have no boost issues. ill will confirm with my tuner if he actually cleaned the control idle valve.
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5277985
lol @ RB30 thing....for starters I would not trust your tuner if his last resort blame was that. As said, engines need excessive air to have high idle.
Did you inspect the new rb26 throttle setup before putting it on the head?
Make sure they were fully opening and closing with no issues and not open too much when closed?
As said you may just need to play with the adjustment. However, usually it is just the idle control valve....
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278061
Did u clean the throttle bodies with carby cleaner? I did this to my 1st rb26 and had similar symptoms. I had to replace the throttle bodies.
Check there is no air leaks at the throttle bodies either. Can also try blocking the idle control valves air pipe. If it idles fine then u need a new idle control valve.
Last but not least disconnect all of the throttle linkages from the main linkage and see if the idle is fixed they might be over adjusted
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278076
+1 ^^^^
If u cleaned the throttle bodies you can get this
Don't know if the idle control valve these guys are referring to is the aac valve but there is also a air regulator under the plenum close up against the block.....this is used for cold starts.
If it is shagged or unplugged you will get similar symptoms.....to reach it is a real bitch! .....good luck
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278112
hi i had that exact same problem on my other car that i sold an i tryed heaps of different things an guy who bought it called me a few days ago to tell me all he did was replace the AFM an now the idle has returned to 100% normal, so diffinatly check that..
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278698
lol what?
Silly tuner you are using mate - go somewhere else if those such comments are being made.
And given you've had power/setup issues for a long time given such comments, perhaps you really do need another workshop/tuner?
As the others have said - it'll be VAC leaks/TB/idle controller. It can't really be anything else :D
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279149
Im not sure if the ECU you are using has the air regulator operating but i suspect so as it runs in conjunction with the AAC valve. As the thread above states it hard to get too but you will have to visually expect that the shutter is not jamed in a position.
I.E At -20 degrees the valve is fully open
at 20 degrees it is half open and
at 60 degrees it is compleatly closed
I am ony guessing and not sure as MAP sensors are tricky but its worth a shot at checking if the valve is faulty. Another trick is the attach a 12volt DC battery to it
Positive to terminal number one and negative to number 2
Say the surrounding area temp was 20 degrees it would open half way (allow a few mins for it to slowly open) and measure the resistance and is should be near 80
The AAC valve should be checked as well, Somtimes the spring is stuffed or the plunger on the switch so also have a look there. Also check the resistance on the AAC valve which shoul read somewhere near 7.
Keep in mind a vac leak will give faulty readings through these valves so thats another place too look while pulling these bits out. (all hoses around the air control system of the car)
Edited by central coast person
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279421
hi
please check the basics
check pipework, solenoids, idle control (basically what the others have said)
post a photo of ETC, SENSOR SW CHECK
post a photo of ETC, FUNCTION SELECT
post a photo of SETTING, REV LIMIT
if you cant work out how to get these, learn here
http://www.paulr33.com/powerfc-emulator/menu.html
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279490
+1 on the cold start valve, I had the exact problem, sitting at about the exact same revs as you.it pretty much sits in between the plenum/intake manifold and low on the head, on the firewall side of the throttle body(if you are running standard plenum). I think its bolted to the intake manifold by 2 bolts. It t has 2 hoses running too it and a plug connects to the top of it.
The way it is designed is a tiny spring inside it is supposed to hold it shut(or open, I forgot). When voltage is applied the solenoid should open or close it. All you will need to do is open it up, be very careful to not lose any parts, reconnect the spring, then put it back together making sure it has sealed perfectly.
Hopefully that is the issue but based on what the tuner said it could even be a tune issue(however I doubt it would rev that high with just the AAC valve letting air in).
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279576
  • 1 year later...
Update on the situation.
Acid cleaned all throttle bodies, replaced the shaft seals with aftermarket ones from the states.
More info - http://www.xs-engine...idproduct=12106
Replaced the AAC valve (23781-05U11)
picture = http://simex.sakura....es-DSCN7515.jpg
3 coats of tomei throttle coat and no difference what so ever.
hi
http://www.paulr33.c...lator/menu.html
hey paul,
Could you elaborate on exactly what the cold start valve is? Are you referring to the "Idle Control Regulator" part no = 22660-01U10?
this thing here?
Edited by Jap_Muscle
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-6035847
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
