What about pics of tool organisation?
I'm trying to come up with ideas of how best to setup my new tool shed.
Hang em all up? Put em in a tool drawer? What about bigger stuff? And the odd one off stuff/tools? How to store/ organise power tools?
there's a thread in the wasteland that has toolboxes and such.
I believe it's titled "show us your tools"
Or there abouts.
Cool tool? My latest buy from Snap On. Cordles 3/8 rachet. Best thing ever when im doing engine bits and pieces including gearboxes or a head.
Best thing i claim it all back on tax as im a licensed mechanic ;)
nice too man.....i wanted to buy this, but bought the milwaukee version instead coz i had batteries
But when you have some nice calipers, there's no point in marking them if you don't have to.
I have a set of Bluepoint ones, but they are a bit bulky. On a lot of the cars I work on the pistons are pushed out so far the tool barely fits in. But they're a definite time saver. I'll get some pics up tomorrow.
to suit opposing piston callipers like skyline brembo and sumitomos, right? where and how much?
Used them on my D2s but yeah would be fine for brembos and sumis. Got it from Transquip, sale price 100, full price 160. Not cheap but pushing caliper pistons back is a pet hate of mine. US ebay has them for around 100 including delivery; here's the ebay search
http://www.ebay.com.au/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XLANG+4+IN+1+BRAKE+CALIPER+PRESS&_nkw=LANG+4+IN+1+BRAKE+CALIPER+PRESS&_sacat=0&_from=R40
  • 3 months later...
Mate you will love those hose removing pliers,,,they are very handy.
Have you tried those caliper pliers yet,,,I was always going to make a set but if they fit inside a 4 piston sumitomo/brembo caliper I'll also buy one.
Cheers
Neil.
Those hose pliers are so cool and definitely one that makes getting the buggers off easier. Lost count of the number of times i have busted knuckles slipping the screwdriver trying to get old ones off.
As for the spreaders, i haven't tried them out yet.
I dont have the twins on the front anymore but if you like i can measure the size of the spreader for you so you can check it fits?
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
