  • 3 weeks later...
Slightly off topic, read a little sticker above the factory wheel sticker this afternoon only to find out that it was running 235/50/18's. argh that they put back on the stock 17's. ok, now I have vented.
typo or legit? if legit that is a retarded tyre size/profile combo
Yep, I'm pretty sure that was it says.
I was just bummed out that they took the 18's off and put the stock 17's on :)
May have been done in australia before or during compliancing.
Your would not have had the 18's, they were only fitted to the ARX and AXIS.
The RS/RX only ever had 17's fitted.
It was not the factory sticker, it was an dodgy little japanese tyre shop job above the factory sticker. I would say they had 18's fitted after, or maybe the 18's were a factory option and they upgraded to the ar-x wheels.
The factory RS was 17 you are correct, but I'm poining out that at some point it had 18's in 235 fitted... hmmmmm nice.
Pics attached
Now I've had a real good look at the sticker it would appear it was done aftermarket at some point in the cars japanese life before it immigrated :down:
If anyone wants to buy my V35 wheels, shoot me an email! :D
How much will you be lookiing at for them?
Any gutter rash?
I would be looking at a semi gloss respray in black so not too concerned about condition of paint, just overall condition of rim.
Let me know :P
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
