OS Giken 3.0 litre kit for around the $20K mark. But there are bigger kits than this..........Spool was looking at a 3.2 and a 3.4 kit.
$20K!!!!
or Rb30 for $200 (or realistically $5 to $10k fully forged and balanced etc)
Charlie still has his apexi 2.9 kit for sale.
http://www.skylinesaustralia.com/forums/Ra...B2-t285391.html
There is also some company out there that is de-stroking rb30 cranks to 83mm, running standard rb26 rods and custom pistons to make an RB29.
User 'Mark99' on this forum was the machinist that developed the stroker kit from memory. I cant remember what the company was called though.
I think he worked for Rhemac in Adelaide.
the 3.2 and 3.4l kits by spool are for rb30 blocks not rb26
Yep, not sure if they will adapt to 4wd, but I'm pretty sure it has been done for the rb30. But I've got a funny idea that the 3.2/3.4 crank throw will not allow the 4wd front housing.............did I read it or am I dreamin' - can somebody correct me???
RB30DET FTW!
That RB31DETT will just be a slightly overbored RB30.
Nitto do the 3.2L kits for RB30 (soon?)
Spool do the 3.4L kits for RB30 (soon)
And I think RIPSNZ do a 3.2L aswell?
OR save your money and just built an RB30DET.. you'd only need the extra 200-400cc if running a HUGE turbo.
P.S. I love my 30 :(
Edited by bubba
love the comments on the rb31 block
i read his thread the other day
he has made it an rb26 open deck with new sleeves, rods and pistons and an rb30 crank
give a better bore-stroke ratio or something and is designed for driveability, torque and response
he has put a lot of work into it but its still in testing and will eventually be on sale once everything is tested thoroughly
on topic, if you want more displacement then you can't look past an rb30 with the 4wd adapter
r.i.p.s in nz will make you a forged bottom end with the adapter and ship it to oz, bolt it in, add your head and away you go
There are a few places now that do a RB30 adapter to run awd. Id say get a dirty 30 bottom end and a Nitto 3.2 crank. They say its good for 1200hp and 10,000rpm.
i like the sound of that.... on the other hand the sound of the price mite not be so good. haha
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
    • Looks fancy But after having a look, prior to its installation, I noticed that the yellow looking power steering reservoir would look crap next to this So I have this incoming..... Much cheaper than the Moroso and has great reviews (yeap, it's a Moroso knock off)
    • Can we place bets? My money is on there is always the option to use the 1 way profile. So the diff is either 2 way and 1 way, or 1.5 way or 1 way.
    • I also used Knox driveshafts when I the slip yoke T56 to the 3bolted TR6060 type. I believe I was one of his first jobs as it literally changed hands when I was there, started by the old owner and finished by the new. Everyone seemed pretty great about it. So wasn't shy/seemed pretty knowledgeable when dealing with weird custom people like me.
