  • Replies 176
I seen your thread...your girlfriend puts hours of work into it and you can't spend a few minutes polishing headlight plastic...come on!
Does the thread have pooper shots?
the first time you wrote it i thought you meant to type 'proper' shots, so i directed to the thread... but now i must ask what a pooper shot is, lol..
Well the proper term is "scot-free", derived from ye olde English expression "scotfreo", meaning to be exempt from royal tax. The singular word "scot" is itself derived indirectly from the Nordic word "skot", which was later influenced by the Old French word "escot". All of which referred to local tax paid to a son of rajab and/or ruler. Therefore to be scot-free you are said to be exempt of charges/tax/penalty.
A pooper shot? Sharpie in the pooper shot. Google it my friend, and then please deliver :/
i googled it and came up with this:
is this what you wanted lol.
stupid fcks no nuffin about skylines, got it fixed and was in no way what you provide me as a solution. Maybe you goes need to go fck urself more.... such a useles forums this is, very helpful dream boats in here too.
well that was a headache to read. maybe you should re-read what you typed before posting.
just a tip.
also why spell 'nothing' like 'nuffin' for? all it accomplished was spelling it very wrong and only shrinking the word down by one letter.
have a nice day:
just a tip.
have a nice day:
well i hope that headach turns into a migraine
If this thread is even remotely true than the simple answer is this:
Your cat collapsed, hence the exhaust temp light came on, which in turn built up a f**k load of back pressure in the exhaust at such a high rpm, which made you lose power and your exhaust to glow so red.
Either way this thread is halarious and the fact you argued about doing such a high speed after saying you were doing 6k in 5th is even funnier. I really do hope this thread was a joke.
Edited by PM-R33
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
