You feel it because you are bouncing around adn on the long sweeper you are falling out of the seat....anyway. Will post up pics to show why they are shit when it comes out again. Need to go back and do my EVO III Brisasaurus seat rail. (ie for prodigious units)
And a few pics from Sunday, my bus next to a friends new EVO. Kind of mutant cousins, both 2L, silver with black wheels :)
Thanks to Martin for the pics from the weekend...the brakes work well :) ... lap after lap :)
Lap 1
Lap 2
Lap 3
Lap 4
The PFC06 pads were really nice when hot. They were a bit grabby when cold which meant I was locking them up pretty often. But when up to temp they were a lot easier to modulate. Seems for the car weight, tyre grip and rotor (cooling) size I need to run a pad which comes up to temp a lot quicker. Also need to get the car's susp setup properly, I have big front ARC swaybar which seems to be unloading the inside wheel when i turn in trailing the brake a little. By the time I start to turn in I am only carrying a little bit of brake but is enough to lock the inside wheel when the big bar ties the sides of the car together and unloads the inside tyre :(
SO need to get the car's ride heights set, rose joints on the front bar set correctly and maybe backed off a little along with a good wheel alignment. has not had one since start of 2009 :)
...and some not so incrimating pics
A shudder developed on the last of the few laps i ran at Sandown last weekend. Show up during the little street driving i did and during the firsf session at winton. Took the wheels off and checked everything was tight and nothing had loosened with the first lot of heat cycles. Nothing unusual but was able to nip up a ted. Checked pads and they were badly glazed. Cleaned up the pads and were brilliant from then on.
So maybe i under did the bedding. Or the rainearly on in the running in of pads/rotors. But what felt like warped rotors was just pad glazing.
That tyre end up feeling like you were driving on a 50c piece after the lockups?
I flatspotted mine at the top of 4th, only just touched the brake and jumped straight off when it locked but the damage was already done. Was like driving on a pogo stick around corners from then on :(
Because my lock ups were typically at the endof the braking zone my road speed was pretty low. You normally only badly flat spot tyres when you have some speed on board. i did actually pick up a flat spot the time i grabbed a brake early in the braking area. It probably was the reason it was locking so often afterwards, even when at lower speeds
Hey Roy,
Love the build up, very inspiring, most brisbane and GC based RB20s get pulled out for 25s or 30s, ive always wanted to keep mine, nothing like the work gone int your tho.
Some thougths on your brakes locking up, id say the front needs corner weighting, did it lock the right front on other corners, when it was inside wheel? It maybe that your ride heights are causing corner weights to be far to light on the passenger side causing the lock ups.
How do you find the power, even after all of your experiments, it looks wuite drivable, power band of 4500 to 8000 i doubt you would drop off boost, so shoud be ok. Does it come on too strong for corner exit traction on faster corners in 3rd and 4th or only in 2nd gear lower speed corners?
Keep up the good work, love it. Just wish I had the money to do what I dream of doing to mine.
I want 250rwkw so a healthy 400 flwhp and then suspension and handling more than more power. My goal is for a set of MCA coilovers, I know his son so support should be good, and go from there.
I spun the Radical out of turn 3 at EC on slicks with a damp track and flat spotted all 4 tyres. I wouldn't have thought it would have done it so easily but with a bit of speed on board looks like its very easy to do.
Car look fantastic mate :thumbsup:
car looks awesome mate. and yeah brissasaurus racing evo 1 seat rail is still firmly attached to my seat mate. :) fark it's heavy though so if you do go ahead with evo III make me one! I'll actually pay for it this time... :)
ps I still have your koyo radiator here mate. want me to send it? or sell it? etc.
come up and stay at my place for a bit. i'm bored, have spare room and a keg of beer.
Just got approved 8 weeks of paid/unpaid leave. First few weeks will be just winding down, then OS then back relaxing...ready for more headfark projects uopn my return. So early July shoudl be some fun at EC/Wakefield and running amuk on Chateau le Count! :)
Thanks rotort...yeh, i love the lil 20. Yes, its still very drivable. I am a bit disappointed its not more of a wrestle to punt...but truth is its still quicker then me so am still chasing the speed the car has. Re setup, the car had a wheel alignment in Jan 2009, since then it has been in pieces, stored and no idea of ride heights etc. I suspect you are right as it only locks the front left when there is a bit of lock on so could be tied up with the too big a front swaybar with rose joints, ride height etc etc.
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
