Phil, No idea when first session is. I am guessing kicks off 9:30ish and may have had one session by lunch.
Still got std diff ratio and std 210,000km old gearbox. There is some money being placed on box not lasting the weekend. I have no worries. Old RB20 boxes are tough :rolleyes:
So the cams gave a sniff that there was more to come. The new turbo has given a sniff that the setup is moving in the right direction.
Seems my R32 is more 58 Plymouth Fury and she doesn't like the extra cubes in her and is playing silly buggers somewhere in the setup. Think dirving around with a head gasket issue with condensation in the exhaust on biref trips etc may have collapse the muffler in the 11 yr old HKS exhaust. I hope its something as simple as that because there seems to be an odd restriction somewhere that means we make ok power but not what we shoudl be :(
Meanwhile, I need this spend to stop so I can count my cash and go buy my Sierra an 80s dance partner at the end of the month
http://www.importmonster.com.au/view?url=http://page21.auctions.yahoo.co.jp/jp/auction/j229858495&thumb=http://auctions.c.yimg.jp/f13batchimg.auctions.yahoo.co.jp/users/1/4/3/5/gensen_fujicarsjapan-thumb-1364822988738188.jpg&title=S62%20GTS%20RBBS17%20AW%20com
i saw this when i was hunting for a caterham on yahoo japan. ;)
Dont know exactly. Tuner and I agreed not to worry about a number. Just run it up, leave plenty in reaserve re fuelling and lets get a good benchmark and some kms on it. Still needs work on fuel setup and cooler piping etc etc. Is somewhere around 300-320. Depends on whether we go for 16psi or 18psi. Dont care just want to it safe to get some track miles under my belt
That's the spirit! Track miles is what it's about!
Well engine seems pretty healthy. Only got two laps before hitting problems but the one lap where I came on to the straight with traffic I was still 24km/h up on my previous best stratightline speed. SO thing has a load more mumbo then the old 98 tune on the 20G.
The only pic from the day, idle in the pits :)
I think its the front right king pin bearing on the hub to upright. Tyre now rubs on upright :(
Funny you should say that, my 34 has just done the exact same thing :(
Engine bay looks great too Roy :thumbsup:
Me too! Kingpin bearing is flogged out. but i reckon mine has something to do with 295 semi slicks and lots of track days haha. They are sooo expensive to replace! Something like $800 each from Nissan Japan. They're not servicable. Gotta buy the whole upright!
Yep i just went second hand and will see how it goes :unsure:
The bearings in the upright (that hold the kingpin) are a serviceable item. I takes some pasence to get them out without damaging the upright, but it can be done pretty easy. I recently changed mine
Edited by sav man
Went through the same deal with Jimmy33t also, he found this number BRG A-KINGPIN 40030-33P12
Its the main one, any bearing shop can match the smaller one. Be careful of the lower seal, expensive item through nissan australia
...sounds like we need a tutorial developed for how to do the kingpin replacement - I'm concerned about mine now :wacko:
How's the gearbox going Roy? My 20 box lasted for 22 years (with 6 years of that mated to a RB25 making around 240rwkw) and it wasn't until I went for mega torque with my GT-RS that it started making bad noises.
Not that hard to change really, found a tapered roller bearing replacement also which has preload when fitted and no shimming required
Here is my graph. Pretty lazy at the moment as no boost or ignition really thrown at it at the moment. Not until we get some kms on the new engine and get the gearbox and rear end/diff fixed.
At the moment there is no EBC, just s soft gate spring with a bleed.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
