I would go for a digital dash like a Race Technology one and run it off the ECU sensors
Is this the dash you are talking about? I'm using a Vipec, can it plug in directly to that?
  • Replies 467
also install my nismo brake master stopper yesterday and dam it makes a huge different to my pedal makes me think my brake masters might need replacing. pedal is very firm now and as soon as i touch the pedal the brakes work unlike before were there was no initial bite
few updates bought some more parts....
ARC Radiator (had no plans to upgrade but this was so ridiculously cheap couldn't past it up)
Std GTR lip
Blitz EBC SBC-3
Nismo rear bushes for shock mounts
ohh and my hks front pipe arrived today 2x70mm -> 80mm; fits the tomei dumps very nicely
The factory tank does a very good job, is mounted well for weight distribution, and has enough capacity for quite a few laps, even on E85....... Hi Octane 32 GTR still runs the factory tank.
Hi Ben,
Do you know what spring rates the R32 runs ?? There's been some discussion on here re spring rates, I'm pretty sure Mark used to run fairly stiff rear springs to stop the front wheels from lifting ?? Probably diff. setup now with Russ driving though.... :-)
cheers,
JB
Well, it had 450/350 (Yes, softer than I run in my Targa 32 GTS!) in it until last weekend when we doubled the rates and had Murray stiffen the shocks to match...... it was terrible around Lakeside, but it also lacked any form of undertray and was porpoising in the front. First time the car's ever understeered. (Same Whiteline bars on soft set, messed about during the day but made no real advances)
With the old springs in it, as you may know it would actually lift the inside front exiting corners, but was a dream handler..... very forgiving and lots of traction. Still seems to be the preffered setup, but time and some sorting may change that.
Edited by Marlin
Would just like to confirm some details regarding tyres and rims.
The best size for track rims would be 17x9.5 +15 ish? correct
and for semi-slick best size selection im like 255/40/17? (do i have to run same size front and back?)
A 255/40/17 will foul the rear guards in an RE55 tyre on a +22 offset. Mine did anyway. So it will get ugly in a +15.
The front is a bit different. With the amount of neg camber you need to run you will probably get away with a wider offset than a +22.
Bridgestone recommend a 9" rim for a 255 bag tyre - you don't have to use drift tyre/rim sizing combinations....
Check also that a 17" rim will clear your brake rotor/calliper. 17" usually means 3345 rotor at maximum unless you are carefull with calliper & rim selection.
Wow, doubling is a big call! it also blows out the difference in front/rear by another 100lbs hence the understeer I'd reckon..
450/350 is softer than I recalled - thanks Benny.
Slightly off topic, but, Marlin... do you know if either of the HiOctaneRacing GTR's use Tomei intake and exhaust valves (+1.0mm) as well as most of Tomei catalogue?
Thanks
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
