I would go for a digital dash like a Race Technology one and run it off the ECU sensors
Is this the dash you are talking about? I'm using a Vipec, can it plug in directly to that?
  • Replies 467
also install my nismo brake master stopper yesterday and dam it makes a huge different to my pedal makes me think my brake masters might need replacing. pedal is very firm now and as soon as i touch the pedal the brakes work unlike before were there was no initial bite
few updates bought some more parts....
ARC Radiator (had no plans to upgrade but this was so ridiculously cheap couldn't past it up)
Std GTR lip
Blitz EBC SBC-3
Nismo rear bushes for shock mounts
ohh and my hks front pipe arrived today 2x70mm -> 80mm; fits the tomei dumps very nicely
The factory tank does a very good job, is mounted well for weight distribution, and has enough capacity for quite a few laps, even on E85....... Hi Octane 32 GTR still runs the factory tank.
Hi Ben,
Do you know what spring rates the R32 runs ?? There's been some discussion on here re spring rates, I'm pretty sure Mark used to run fairly stiff rear springs to stop the front wheels from lifting ?? Probably diff. setup now with Russ driving though.... :-)
cheers,
JB
Well, it had 450/350 (Yes, softer than I run in my Targa 32 GTS!) in it until last weekend when we doubled the rates and had Murray stiffen the shocks to match...... it was terrible around Lakeside, but it also lacked any form of undertray and was porpoising in the front. First time the car's ever understeered. (Same Whiteline bars on soft set, messed about during the day but made no real advances)
With the old springs in it, as you may know it would actually lift the inside front exiting corners, but was a dream handler..... very forgiving and lots of traction. Still seems to be the preffered setup, but time and some sorting may change that.
Edited by Marlin
Would just like to confirm some details regarding tyres and rims.
The best size for track rims would be 17x9.5 +15 ish? correct
and for semi-slick best size selection im like 255/40/17? (do i have to run same size front and back?)
A 255/40/17 will foul the rear guards in an RE55 tyre on a +22 offset. Mine did anyway. So it will get ugly in a +15.
The front is a bit different. With the amount of neg camber you need to run you will probably get away with a wider offset than a +22.
Bridgestone recommend a 9" rim for a 255 bag tyre - you don't have to use drift tyre/rim sizing combinations....
Check also that a 17" rim will clear your brake rotor/calliper. 17" usually means 3345 rotor at maximum unless you are carefull with calliper & rim selection.
Wow, doubling is a big call! it also blows out the difference in front/rear by another 100lbs hence the understeer I'd reckon..
450/350 is softer than I recalled - thanks Benny.
Slightly off topic, but, Marlin... do you know if either of the HiOctaneRacing GTR's use Tomei intake and exhaust valves (+1.0mm) as well as most of Tomei catalogue?
Thanks
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
