Howdy Folks,
Just Wondering if anyone is entering there cars this year for autosalon?
Not sure if SAU have a stand there this year but it should be a good turn out.
Hopefully not toomany Chromies with failed offset and more JDM..
Auto Salon 2010
Melbourne Show Grounds
Date: 28 & 29 August 2010
Opening Times: Sat & Sun 10.00 – 18.00
Parking Facilities: Public Parking $10 at Flemington Racecourse, enter via Flemington Drive on Epsom Road
Public Transport: No 57 Tram from Elizabeth St outside Flinders Street Station to Epsom Road
Entry Gate: Pedestrian Entry via Gate 1 Epsom Road
Website: www.autosalon.com.au
  • Replies 191
lol 20-25 and they have gone to a cheaper venue?
hopefully more than previous years... its been a pretty weak show over the last 3 odd years. Im going to walhalla for the weekend so cant go.
Ye i doubt it, all went downhill after certain people left, and the resulting replacements starting dicking clubs like SAU around, infact so many clubs don't go anymore which is unfortunate and sadly was quite often where some of the more realistic/awesome cars came from.
I am entered in autosalon. have my own stand with a about 12+ cars. entry fee is $25
cheap venue this year apperently at the showgrounds. personally not a fan of the new venue but will see how it goes i guess..
got a nice JDM stand setup. so if you come down feel free to visit the Auto Indulgence Stand. 3-4 sau cars in it :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
