yeh i tried the delta an1 - an2, doesnt seem to work for me, so i just use an1 and have tried to calibrate it to read the same as the gauge, but under WOT it doesnt seem to be the same,
i have tried different earths but the instructions and their website say u must try to connect all earths to one lug, even the signal and heater grounds together.
i have it working now with the gauge but every now and then it freaks out and i have to jack the car up take the 02 sensor out and do a free air calibration then refit.
ignore their website in this case, i tried all of recommended setups i found on all sorts of sites and none worked. wired it up delta but without the option selected and used a seperate earth for atleast the heater ground and it worked perfectly. just keep trying different setups until it works
  • Replies 50
ok cheers, ill try this this morning, to me your way makes sense, surely the heater ground would put a lot of noise/ signal interference through the system ground which is extremely sensitive.
to keep on topic i got my standalone innovate from ebay, think it was $350ish
http://wbo2.com/home/default.htm
they arent hugely expensive, they are a local product and they work well.
I got mine from these guys - and the amount of information on their website, plus the speed of response for any issues is awesome. A++ would buy again
but the tech edge is super ugly LOL
im thinking of getting the LX1 display with 2J2 controller + bosch sensor = $394
anyone using this particular unit/combo, also thinking of outputing narrow band to ecu as my o2 sensors arent working
thats the setup i have except using the older 2J1 unit. With the R32 they use different o2 sensors and im not sure if the feed will work properly. (or was it only some of them that used the funky sensors?)
  • 7 months later...
Just some more innovate info i came across which mirrors my experiences:
I was the original sole Australian distributor for Innovate and literally sold hundreds of LM-1's and LC-1's and can personally tell you they are garbage, I got sick of customer support and needing to work around their glitches.
Short story is if you use a proper AFR instrument (not a toy) then you will have NONE of the issues they crap on about! regardless of where you place the sensor and no magical "lean misfire spikes" LOL........ I find it funny now, but was not so amusing when I had to deal with that crap every day.
I use in my own car a Japanese NEKO Corporation AF700, it feeds into my G4 and also my BLitz boost control and all three give and log exactly the same figures, and my sensor is located right of the back of the turbo. The other instrument I use is an Autronic B model meter when doing back up checks or other cars, again never ever an issue. Both of these professional instruments use lab grade NTK sensors and not the hobby shack Bosch LSU.
Little tip for the day.
Not the most compact option Trent. lol. :rolleyes:
http://www.rhdjapan.com/neko-corporation-af-700-air-fuel-ratio-meter-system-31063
I still have had no problem with my Innovative, well over a year of everyday driving on ethanol. I installed an AEM the other day for one of the Stagea guys, not a bad unit for $200 delivered either...
Yikes! it would want to be better than the innovative at 5-6 times the price!
Question for guys running a wideband, do you use the aux output to replace the standard narrow band signal to the ECU?
Edited by battery
I didn't, I ran the narrowband in the stock dump location, the wideband a foot down and a temp probe right at the turbine outlet. The dump looked like a mess.
One output to the gauge and the other into the Emanage.
I have a bung welded on my front pipe after the merge and wondering how everyone is running the wiring into the cabin, I don't want to go through the firewall
I had look underneath passenger side but can't see anything I can work with.. Am a lil blind btw :)
Innovate released a new O2 gauge setup in November last year, It's called the MTX-L, unlike the LC-1 that has a control unit and then a gauge seperate, the MTX-L has everything contained within the gauge. This keeps the cost down as they were aiming to make it the cheapest Wideband in the market.
http://www.innovatemotorsports.com/products/MTXL.php
I picked mine up for $199 + Postage from;
http://www.superiorautoparts.com.au
Edited by D_Stirls
I run mine up through the gearshifter hole.
run myne through with the main engine loom into the passenger footwell
i like the idea of the controller integrated into the gauge. wonder if they're gonna be more reliable than the lc-1s tho. still use the same bosch sensor which is a little gay (killed 1 in only a few months of limited use).
Like I said, my Bosch sensor is still going strong after over a year on Ethanol and 100 dyno runs, mounted close to the turbo. I know moisture can ruin them if installed in the wrong orientation but I guess there are always bad batches. I know Trent had to change them regularly and I suggested to him it could be because the cars were being tuned and running rich as F*#K causing carbon to build up on the sensor. Only a theory though.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
