Quote: If your application requires a twin scroll T04 flange, then you're in luck: the twin scroll T04 housing bypasses gasses from both scrolls making this the first aftermarket performance and racing turbocharger to offer a twin scroll internally wastegated turbine housing.
Mmm, nice.
Mmm, nice.
Mitsubishi have had internal waste gate twin scroll turbos since the Evo 4.
Nothing new, but still cool.
I will have the catalogue in my hand probably tuesday. We will make my next turbo selection from there.
I've pretty much made up my mind these borg warner's are where i want to go.
BTW, the EFR turbos are at the higher end of the aftermarket turbocharger price spectrum. The reason why is because they are so feature rich........ If you look for quality and don't mind spending a premium then keep reading.
Taken from one of the links... I guess BW turbos had there stint as being very well priced in comparison with Garrett.
Friend will be back on deck from sema on tuesday and will hopefully have all the relevant guff we need to make the selection we need.
That and I'm an old prick. would rather have a paper catalogue than the link you posted that wont open for me anyhoos. :ermm:
There are some prices in the link I posted earlier. 2.7k US for the external wg 8374... so over 3k landed. Hopefully these are only preliminary numbers...
nasty pricing
surley they would stick it to garrett by matching prices initially
ill definately be holding off if they cost that much, untill they are proven to be the shit by one of you guys
So nearly $3k for turbo, plus Full-race manifold $2.5k (landed), twin wastegates $300ea; you are over $6k and you have no gaskets, dump pipes, intake pipes... Halve that at $3k and a set of -5's would be fine thanks!
And you get the gaskets lol
is you'll find that the Series EFR turbos are unlikely to directly retrofit into existing T25/28, T3/T4, or GT30/35/40/42 fitments
Indeed a very costly exercise to become a guinea pig!
The BOV placement is interesting, in a space conscious bay, that could be a bit of a problem.
Another possible drawback is that the turbine housings are not available in various A/R sizes due to specific gas flow optimization for the housing and wheel shapes. It is possible that BW may release other A/Rs in the future, but for now the T25 inlet wastegated housing is only available in 0.68a/r, the T3 open volute (single entry) wastegated housing is only available in 0.85a/r, the T4 divided (twin scroll) wastegated housing is only available in 0.95a/r, and the T4 divided (twin scroll) non-wastegated housing is only available in 1.05a/r.
Interesting...
Like the idea of moving the mount points thought, nice and easy.
Well the Sierra Sierra EVO has knocked 2 seconds off its personal best (which happens to have been the lap record for the track, which it took off HKS) at Buttonwillow on the first day of US Superlap using an EFR8374, gotta be promising...
so probably no twin option for a standard capacity GTR hey... if GT-RS size is the smallest they're going... if they have that size that spools like the old 2530s then I'll take 2 thanks;)
they are testing twin turbo IWG applications at the moment on a couple of GTRs. I have some pics but not sure if I can share them yet, but set-up looks good. all that remains to be seen is results. ;)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
