I have the catalogue in my hot little hands now and will venture over to elite racing to sit down and have a conflab with dan'el sahn as to wether this product is a viable proposition from a dollar view point.
Quality comes at a price it would seem.
Will you change the manifold as well to run twin gates?
Well the Sierra Sierra EVO has knocked 2 seconds off its personal best (which happens to have been the lap record for the track, which it took off HKS) at Buttonwillow on the first day of US Superlap using an EFR8374, gotta be promising...
Hard to put that down to the turbo alone though.
Of course, but I would suspect it has got to be partly to do with it given they'd been whittling down to match HKS' time previously then suddenly are able to knock another couple of seconds off.
Big development packages, always nice when changes work Lol.
For that level of performance increase I would be thinking major aerodynamic update in conjunction with everything else.
Be very interesting to see how these BW turbos shape up in the pretty competitive twins ~ 450 - 600 HP bracket.
It would be quite difficult to improve 2 seconds a lap on the aero package they were already using. According to those guys the car had enough downforce at superlap that it could actually drive upside down.
Sharing is caring Mr Baron :P
well since someone else posted this i am excited for these i have been talking to geoff @ full race bout these for a bit about these pretty keen to give the
6258 or 6758 on as pictured for my new motor..
was told not to post up the photos however.
was hoping for stock location low mounts but these i think have changed my mind.
And then Garrett go and release the GTX graphs LOL
Decisions decisions for you :dry:
I found those photos on the UK forum... that being said it looks very messy in there. Are these new improved turbos (considering the Garrett GTX series too) worth the extra $$$ for the extra performance; and is it quantifiable yet? i.e. 300rpm better spool or 1000rpm?
Bigmikespec - I think the thing about these turbos is that for a given size the spool/response should be a little better (ie, EFR8374 equal or better than a GT3582R in spool) but flow like a GT4088R or a T04Z... so if you are matching for a given power level you could argueably have a far far more responsive turbo than previously.
Take this unit: http://www.full-race.com/store/turbos/borg...6758-turbo.html
Flows somewhere between a Garrett GT3071R and Garrett GT3076R with a turbo that would be more comparable packaging (and potentially response) wise to an HKS GT-RS. For the people who get all wussy about GT30 spool when aiming for 250+rwkw, this could be a bit of a "new black" option.
Only 4 in the last couple of years. :thumbsup:
Crikey, in what kind of conditions?
Street, Track, Strip. doesnt seem to matter, I have a friend in a similar situ with these 35r turbos. He has done the same amount in the same time frame.
The feedback from the last turbo (which looks remarkably similar to the 35r from the sierra sierra nightmare) is that we are spooling the turbo too hard. Given the selection process i fail to see how. Garret claim the turbo is good for 2/5 litre engines, We're using a 3 litre. We are only using 23/24 lb of boost and the revs are limited at 7500 rpm.
Theres something not right with the 36r imo. wether its too much turbo for the cartridge size or something else I have no idea but there is too much evidence both real and anecdotal that it has a definite reliability problem when pushed a bit.
I am not going there again.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
