I think the point is, 3 pages of nothing but walls of text and marketing talk. When it was as simple as saying something like this:
"The 9810 turbo failed, we don't yet know why as to the cause. We will use something else for now"
Rather than dancing around the issue, avoiding the questions & laying the foundations for an elaborate story etc etc. All that does is make it sound like there is more going - and now posts are getting edited (does it get better? I'm scared to leave the keyboard incase the next installment is even better :merli:)
Part failed, part failed. Shit happens. You get another and hope it don't happen again.
I've had a near new GT30 fail, not been scared to say that. Similar issues to ole mate Noel i would say as well :D
whose to say if the house brick was hit by the moon module or if perhaps your house brick actually jumped off the floor and hit the module as it was minding it's own business mid-hover in your living room? I think your warranty will be paid but only in 3 dollar bills as per your original purchase.
Just another example of how big business never believes the poor consumer. My brick was totally innocent of your outrageous allegation.
bot. If the turbs failed it failed, regardless of curcumstance. I've been around long enough to know these things happen and I certainly wouldnt judge the product on a couple of early problems.
Time will bear out wether the product is as good as Borg Warners hype. I hope it is. Garret have had it their own way for far too long.
couldn't agree more. i am just as anxious as the rest to see how it goes. from what I've seen it looks positive. hopefully when we get back to testing one on marks car it will do what we want. nothing really to do but see what happens. I'll leave it at that.
More to this point, the fact it came out that the turbo failed in the first place and was NOT discussed is why theres so much hoo haa right now.
Even right now we are still discussing the matter in grey text, further adding fuel to the fire for anyone without the capacity to see beyond face value and further defacing the 'slow built' reputation of this product and its sponsors.
Had the cat not been let out of the bag, that is a totally different kettle of fish. Now its known that the thing died and to any 2 digit IQ baring reader they will certainly see a conspiracy brewing.
Eh, c'mon.. Just say it already, damage is done.
Shittest pictures in history, but you get that.
Had Dales (d_stirls) brother machine this up for me;
Perfect copy, just in super pretty alloy. Nipple has been offset slightly for various reasons that don't matter anymore...
Anyway, should be available for people soon.
And on that note, I return to packing for WTAC! :D
Another thread including another blown EFR (EFR6258 - which was replaced by an EFR6758), but at least some otherwise decent performance results were measured from both: http://www.vxronline.co.uk/forum/showthread.php?121019-Aussie-GMAN-s-Astra-G-SRi-T&p=1825669&viewfull=1#post1825669
Did anyone consider that maybe he would love to share what happened but for what ever reason he just isnt allowed to?
Why is everyone so quick to assume these turbos are junk? So many things can go wrong and destroy a turbo without the turbo ever being at fault. Lets stop assuming and continue waiting for results.
SIerra sierra will be running a 9180 at superlap. That should be a good test as it is famous for killing turbos.
Who is assuming they are junk? It is a discussion on BW turbos and that includes successes, failures and in this case possible failure.
Everyone wants to know what happened.
+1 Certainly no-one is saying they are junk.
However the limited shipments, if it comes out that a number of them are failing (even after testing)... That is an issue that needs attention & something that can be fixed.
Also sounds like BW customer support is 100x that of Garrett who simply don't care which is a much needed thing in the performance turbo world. Obviously just a pain in the a$$ that you potentially have a bit of a wait for another to arrive at the moment.
Well the Sierra Sierra Evo was clocked the fastest down the straight (280kph IIRC) with a 9180 on it.........They were accused by the Jap teams around them of running NOS (illegal)
....Who can knock Tarzan out of his tree next year?
Edited by Sub Boy32
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
