Thanks, but I'm well aware that you've previously posted those results, not really any need for name calling, most of us are adults here
You are the one that name called, and I wasn't saying that was the differences so much as saying you could safely expect at least that much...
My post generally stated disbelief at the disparity between roller and hub dynos. 70KW is substantial figure in anyone's language, hence "Nigga please"
My comments weren't aimed at anyone in particular, just a general statement but when simonR32 decided to call me a dickhead, as if I had not read the thread and seen the results posted about, which I clearly had considering they were literally 2 posts above mine, what do you expect me to say ?
I wasn't commenting on what you said at all Lithium but rather generally about SimonR32's post.
as for the dig about dyno figures in perth, the fact that I seem to have touched a nerve speaks volumes, do a forum search and see what comes up, obviously I'm not the only one to make this sort of comment. (Queue 900 people from perth having a sook/teary about this and that dyno being the worlds most accurate"
In the end it comes down to the fact that when I see something I think is a bit odd, I'm going to call it straight up.
This isn't netball, like I said we are all big boys and manners cost nothing, so what's the problem.
I didn't call you a dickhead. I commented that you made yourself look like a dickhead which I think is unusual for you (after reading posts you have made in the past). If I wanted to call you a dickhead I would have, I didn't and I chose my words wisely, so please read it in context.
It must be the air in wa that makes the dynos read high because they are the same dynos with the same calibration and corrections :-)
It's ok though, my shitty 480rwhp seems to keep a few 700rwhp Eastern states GTR's honest :-p
70kw is a bit much for me I think but between two dynos even with the same corrections anything is possible.
I probably bit a little bit hard over nothing so I'm just willing to chalk this up to miss-communication
and no chance mate, we build our tracks downhill over here :rofl:
I don't really have anything else to add so here is a sweet Miami Vice picture.
It nearly runs a 10 and two different machines measure its output no doubt on different algorithms and different variables.
Enough sooking, is don is good.
On a plus note.....
My 8374 TS IWG should be shipped this month, So early next month it should be in my hot little hands!! WOOHOO can't wait!!:worship::cheers:
I am getting a Manifold made here for it, So there will be a little wait for that.....I would have loved a Full-Race one, They are a work of art....But it starts to add up getting one from the other side of the world.
  • 3 weeks later...
dont know if anyone can confirm this.
But i have been told by a large Aus supplier that BW may be dropping the whole EFR range due to 'internal problems" in that side of the business.
apparently they have spent so much money on R&D , marketing etc and has cost BW lots of money. and the big bosses at BW may scap the whole thing.
i know i ordered a turbo in march this year went back to supplier yesterday and they still cant tell me when one is arriving,
Given the amount of secrecy that seems to follow them I'm surprised such information would have leaked. I mean people won't even say a single turbo shat itself. SIF a full production shut down would get out.
I heard that they were having trouble with there suppliers manufacturing quality control and have had to find a new supplier. If this is correct, that would take a fair while.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
