Congratulations on the result, but the No.s seems low for what its got.
I have a Garrett GT2871 56T in .64 rear in my 180SX SR20det with Tomei Pon cams and that made 260rwkws on 18psi with pump 98 fuel. 261rwkws on E85 is propabably just pass 230rwkws on pump. Whats that turbo equivalent to in Garrett range?
Cheers!
Couple things to consider about the number, 1st, I have a leak somewhere, so I'm bleeding boost, I peak at 17 but drop fairly quickly down to 15, ergo, it's not running at its potential. When I get that leak located and sealed, I can run 17-18psi the whole range, and probably pick up a good handful of kw.
Second, it's on a Mainline. The Willall dyno is a pretty hungry little thing. I could roll up on the nearest DD and pick up 20kw on the same day.
Hell, for all I know I'm running out of fuel. I was too excited when I picked it up to worry about such small things as injector dc...
As to its equivalent in Garrett... Shit. I don't really know. Equal parts 2871 and 3071. But it feels so much better than either of those.
I dont understand the comment re a small number, it is an EFR running 17psi...... Arent these things designed around massive PR's? I think its doing a great job, knowing you have E85 up your sleeve you should definitely squeeze at least another 5psi out of it.
How much can be expected from something thats 'all in' at the 3400rpm level on a baby SR? LOL. IMHO Your motor is going to free up too, a years worth of sitting around will make it pretty lazy off the bat.
Well. I like your results. They make me wonder if the GTX still have their place on a 4 pot, and your not at full tune yet. Good work!
P.S. f**k YOU BORG WARNER, hurry up and make these things readily available :P
When I get the leak sorted, I'll think about an extra few psi. I'm not sure how much fuel my tiny little 850's have left in them though...
I don't think I'll ever be able to go to Garrett as a first option on a Nissan, hell, on anything after this. Everything just feels so damn good about it.
Defs glad I ordered mine when I did.
And now for what everyone has been waiting for. I got tired of waiting for the readout to get emailed to me, so I did the typical internet thing and took a photo of the printout.
I've only ever seen 1 legit 2871 result come close to this in terms of response and outright power. It was all in in the low 3's, peaked around 270 and rolled off after 5500. Pretty sure it was running 50/50 98/e85 or something with the cams cranked way over to get response.
Anyway. The potential is obviously there. For a baby "bolt on" to have that sort of power with mid 3's response is extremely impressive.
If you aren't out of injector already you will be once the leak is fixed. ID2000 time.
Haha I'm serious lol the Toyota can eat a dick for all I care ATM
Keep finding s14s for sale and seeing what an effectively bolt on turbo can do excited my pants
Come drive mine once its off the rollers next, if it turns out as per the last one that I did with this exact setup (this motor has .5:1 more CR, hopefully its not a negative thing) it should be ballistic.
Ive already got it pushing me back at 2000rpm. Praying it works in full this time.
Missed this. That is a concern, but I'll just deal for now. Should be enough left in the injectors when the leak is sorted. After that I'm just gonna drive it and enjoy it for a while. ID2000's, more boost, 4.11 rear, etc may come later, but before I even think about that, I'm thinking BM50.
Someone must know something about the EFR 7163. The only hints at real-world use are a password protected entry on the Perrin blog and a video that has been removed from Youtube. Has BW changed their mind about releasing it and trying to destroy the evidence or something?
I know that I have a pair sitting in my garage at home.........
So without dwelling on it too much more what turbochargers were you using and what was overall opinion on the twin configuration? It was a very packed engine bay with it all in there.
Having been through the twins already, retropectively would you have gone a single EFR or would you in future?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
