I think that the point of variable intake cam timing is to be able to have the torque building / boost earlier (better cylinder filling... ), whilst also having a large duration at higher revs.
Oke since it was said that the 7670 did not flow enough for my hp goals I made my decision :)
Since my car will be mostly street and occasionally track I think this one will do the job for me.
More power and less hastle with external gates and pipes.
Efr 7670 ewg next to the efr 8374 IWG (twin scroll)
This one has a sand casting too btw.
which motor ? :)
Its been send back :)**new in the box** so I get my full money back.
Geoff said it is hard to get past the 500whp line with the 7670 and I am aiming a bit higher than that.
That said this turbo can deliver much more, the cost vs the 7670 is a bit more but I wont have to get external gates since its an internal and I dont have the trouble of dumppipes so its much cleaner.
So the in the end the cost of the turbo setup will be lower.
Edited by Impulse-NL
  • 1 month later...
hey guys,
for the EWG Single RB26.. I heard that the R32 full-race rb26 manifold need a single stage powersteering pump ( from a rb20 or rb25) in order to clear some lines, is that true ? can we simply bent/replace the line in the way instead of replacing the pump ?
hey guys,
Provided you have ditched the HICAS you can remove the rear section of the standard R32 GT-R power steering pump, the pump is modular and is pretty straight forward to work out when you pull it apart, the only modification required is to have the shaft cut down and re-hardened.
Here's a picture of mine on my build log, almost at the bottom of the page.
http://www.gtr.co.uk/forum/154737-sub-boys-r32-gt-r-then-now-2.html
hey guys,
Hi cobrAA -- for the Full-Race single turbo manifold, you can use any power steering pump you like. the RB20/RB25/R33/R34 single stage PS pump provides the best fitment but its not mandatory to do.
However - Our twinturbo EFR kit is mandatory to use the single stage PS pump
I must ask, with either modification ( either yours or the R33 pump) will I need a new belt as well ?
belt does not change - just converting from a twin stage (for hicas) to single stage (non hicas)
the 82mm is a monster turbo and the 87mm turbine wheel in 1.25 a/r works very well. However I prefer twin S300SX to giant single S400 or S500 when targetting really big power numbers. although for a drag car singles are no question easier to package and service, both have their upsides
Edited by Full-Race Geoff
Im not the type of person to get into forum arguments but it seems you guys are villifying 'the keeper' and truthfully he was John's biggest stateside supporter.. so Ill briefly share my point of view of the events that transpired last July/Aug:
the (4) turbos that failed for john, were successive serial #s. we initially saw the first 2 turbos from this batch fail but we thought it was a freak occurence and had not seen it previously. none of the previous EFR turbos we've used had failed in this manner. John installed/killed the turbos and sent them back which was when bw learned that this batch of turbos had turbine wheels which the supplier did not follow strict mfg requirements. had we known about this prior to john the turbos from that batch and serial #s would not have shipped to him. Unfortunately we did not know, so the turbine wheels failed immediatley and now every EFR turbo that shipped since then has been verified by BW to use correct turbine wheel
Full-Race's twin turbo RB manifold was designed in R33/R34 engine bay. we did not know R32 fitment because we never had an R32 GTR to test on in the USA. In fact we've just recently imported an R32GTR clip to solve this fitment and make the install much easier for anyone who does this in the future.
john - I thought it was made clear to you and richard that a replacement manifold OR credit for your manifold would be issued to richard (he is the one that paid for the kit iirc) to help cover your time. Ive been the head of Full-Race for 10 years, we have never had this situation arise or done this before. Richard said he needed a single twinscroll turbo manifold and suggested we would apply your credit to that. fyi This twin turbo kit is not compatible with a dual stage 32GTR p/s pump obviously, any of the Rb single stage pumps would work- RB25 or 26.
that is what I recall also, build a second set for him, or issue a credit to richard... of course discussing/solving this through a public discussion forum is probably not the best course of determining that
correct
you have more experience running the twin 6258s on an RB than anyone else on the planet, so you know first-hand how well the combination works. I also agree that if John had just installed his 6258s this time around he would have been pleased. Instead he tried the larger 7163 turbos out, which in hindsight are clearly too big for his application and stock displacement 2.6L
this kit has not been offered for sale publically, it will in 2012. The R32 GTR fitment is much tighter than R33 or R34, so thats why we brought this car in - to get the fitments perfect.
at first i did not believe it was possible to acheive their claimed dyno and quarter mile performance on the little 6758. ive had a lot of conversations with oem Auto mfg engineers and direct injection specialists lately who tell me otherwise. gasoline direct injection really changes what is possible
Hi Geoff do you have a list of serial numbers effected? My 6758 purchased from GCG has had the turbine snap at the shaft also. The unit has completed two events. Approx 100km. I'll check what the serial number is and report back. Ok the box says 233 13 0012.
Edited by BoostdR
In the interest of full disclosure. The car was running 26psi until yesterday where it was peaking at 29psi-30psi due to a more free flowing 80mm intake over the previous 62mm.
Looking at the Motec logs, failure occurred during tyre warm up right on the rev limiter of 7200rpm. The car does back fire at this point. Boost at the time was 20psi.
I will never run anything other than an EFR. I have owned 76 cars and tuned countless others. The transient response of the EFR is better than anything I have previously tested or run.
My Questions for Geoff are:
-Am I able to get an RMA or at least a replacement turbine and backing disc?
-Would passing the 154,000rpm range cause this failure?
-Is failure increased with ignition cut rev limiters?
-Would I be better to run a 7163 to bring shaft speed down for reliability.
-Was this an early generation EFR turbo failure (233130012) and I can run my 6758 all day at 30psi?
Regards,
Edited by BoostdR
Rb25 with rb26 crank and bored to 87mm
Tell us how the 7670 drove mate?
tell us how the 8374 drove ?? Really anxious to see how my 1.05 8374 will feel on my rb26 ( head will be slightly ported) ! If I don't like the spool, I will either go 7670 1.05 or IWG ( kinda stupid considering the money and time spend on fitting the dual wastegate and plumb back)
  • Like 1
Regards,
Mattattachicon.gifImageUploadedBySAU Community1427592555.960490.jpgattachicon.gifImageUploadedBySAU Community1427593888.471086.jpg
hi matt, glad to know you like the turbos. I can understand your wanting to understand what happened here, but quoting that post from 3+ years ago seems a little pointless to me... in response to your questions
-Full-Race can not help you with this, we did not supply the turbo
-turbo overspeed can cause turbine wheel failure, yes
-unless your setup causes turbo overspeed, probably not
-without question, keeping shaft speed below "maximum" is a good idea
-i dont have any information on turbos that did not come through full-race, it would be in your best interest to contact your supplier and have them handle things from here.
Thanks for the reply. I will grab a speed sensor and get some real life data on my setup. I think it is highly likely overspeed was the cause although not specifically at the time of failure. The car was making 480hp on a 2ltr.
Could a contributing factor also be an extreme short term increase in turbine temp vs shaft torque? The car also does run a crude ignition retard form of anti lag.
Edited by BoostdR
GCG were able to also advise turbine speeds over 153,000 rpm could cause failure. They reported quite a few failures of the 9180 used in time attack under extreme conditions.
Another possibility after reading Borg Warner's Failure Analysis info is the possibility of my dump pipe causing misalignment of the turbine housing during tyre warm up. ie: 6000rpm clutch drop on Hankook Z221 265 softs. The fact the boost pressure at the time of failure(19.9psi) was low would support this theory. I can certainly improve the dump pipe support as the current setup mounts to the turbo and then solid mounts(after a flex) to the chassis. 480hp on the OEM engine mounts also wouldn't be helping.
Matt
Edited by BoostdR
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
