  • 1 month later...
Hi Geoff,
Which would spool better on a 2.8 (full Tomei 2.734 engine) relating to the EFR8374
1/ TS T4 0.92 IWG with TS T4 manifold or
2/ SS T3 0.83 IWG with TS T3 manifold
Presently have Garrett 5s and 9.0:1 compression 260/10.25 procams that runs sweet no surge shuffle what so ever and is quite responsive, just chasing more of it haaa need it more to the left, higher and flatter ! Only have high octane and no syrup where I live.
There are not to many graphs around and the ones I have seen do not seem to come on boost any better than my current setup.
Been through this blog a few times and seen the blue R34 gtr on your website that would be close to mine but you are not showing a decent graph.
I hear though that the transient response is real good.
I use my car mainly on the street and winding hills where I live so enjoy good response and also take it to Suzuka around 3 times a year.
Overrated mate save your money. Your response looks better than an 8374 for sure.
I have never seen a convincing dyno chart for and rb26 or 28 yet even though these things have been out forever.
Will be interesting to see piggazis and Harrisracings when they eventually post a chart.
The thing is efr's on the dyno don't show up there driving experience. Throttle response is night and day different, power before the spool zone is very different, part throttle boost is again much better. You have to drive an EFR equipped car to understand. They just want to spool all the time. I can get 5psi on my little 2ltr WRX at idle just by retarding the timing from 15 to 5 degrees. In the same vein there is a reason why a heap of OEM cars have a low rotational mass ceramic turbine, also why a lot of new OEM cars now use Borg Warner technology, A45 AMG for instance.
http://youtu.be/d16w0PjkEYk
Edited by BoostdR
Hi Geoff,
if swapping only manifold and turbine housing - Twinscroll T4 will spool better when properly implemented. I am generally not a fan of SS T3 for most inline 6 applications. for a street/winding hills setup and occasional Suzuka trip the 8374 could work very well as could 9174 if you wanted a bit more top end power or bragging rights dyno sheet. Have you considered twin EFR6258? that is a great setup also, here is a recent chart from a customer build:
nissan-rb26dett-efr-twin-turbo-kit-1-con
The more I read about these EFR turbo's the more I need to have one. If they made either the 6758 or 7163 in T3 and external waste gate, I'd be upgrading my HKS GT-RS in a heart beat.
the 6758 and 7163 are both available in vband inlet, external WG config. The turbine housings are stainless steel its easy to weld a T3 flange over the Vband inlet. I posted a photo of this somewhere in this thread if you need me to dig it up. these will make a GT-RS seem like a dinosaur
experience driving an EFR behind-the-wheel is the only way to truly understand how everything works together. People naturally want to measure everything and compare turbos for pissing contests or advertising purposes... and when the only tool you have to do that is a steady-state WOT dyno, the good stuff can be lost. there are many things in life where a chart or an explanation over the internet can not do justice
it is easy to look at dyno charts, and go on forums where the dyno chart is what matters... outside of forums there is an entire world of racing that does not care about dyno charts. feel free to do some digging:
07-19-Points-Chase-Entering-MidOhio-Std.
a little closer to home:
http://www.speedhunters.com/2015/06/a-skyline-gt-r-tuning-revolution/
Edited by Full-Race Geoff
Hi Geoff,
I definitely prefer the single over the double so most likely will get the 8374/0.92 IWG. Like the simplicity.
1 question Geoff, do you do a downpipe for that turbo to go to a standard position Cat ( r33 gtr) obviously using your manifold.
Do all my own installations at home but not so good at making downpipes. that would be cool if that is possible.
Cheers Mike
Geoff,
Can you provide a v-band EFR turbo already modded to T3?
Which in your opinion is a better replacement for the HKS GT-RS, the 6758 or the 7163? I don't want a less responsive turbo, but the 6758 doesn't look like that much more power than the GT-RS.
Thanks
Contact Nisspeed. James has made a beautiful t25 to T3 adaptor.
That turbo looks like it is going to rest on the right side when the engine shifts around.
The picture makes it look like that but there is about 1.75" gap. Can get 17psi just leaning on the OEM stall convertor (c34 Stagea). Lag was obviously a concern with the heavy auto.
Hi Geoff, Have you had any results with the EFR 9174 hybrids? i've read the spool performance is only 50-100rpm down on a 8374 but your compressor efficiency moves up the revs a fair bit.
also, i remember seeing spool diverter valve a while ago. is there any plans for Borg Warner to release it for the larger frame exhaust housings?
Edited by burn4005
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
