Overrated mate save your money. Your response looks better than an 8374 for sure.
I have never seen a convincing dyno chart for and rb26 or 28 yet even though these things have been out forever.
Will be interesting to see piggazis and Harrisracings when they eventually post a chart.
Sorry for the delays in my project, but I'm back on it and set my goals to have that thing dyno'd within 45 days. I'm trying like hell! Trust me, I want to see an 8374 efr dyno on a stroker as well :)
theres an RB30 + 8374 dyno chart from Chris Vautier (new zealand) somehwere in this thread: http://www.gtr.co.uk/forum/154737-sub-boys-r32-gt-r-then-now-66.html
Holy smokes is that really 630 whp on PUMP GAS?!
Well I'm hoping to hit my target of 550 whp on pump gas. Any more is Lagniappe as we say down here :)
Anyone running one of the newer T4 TS 6758's on an SR20? Can't find tooooo many people around with the setup. Thinking about going low mount T4 TS manifold and 6758 T4 TS 0.80 turbo (stiffer spring on internal wastegate) on my S15. It's daily driver. Some weekend warrior, and occasional track day. I'm all about that response. Poncam, Z32, 2000cc injectors, Forged engine, RB25 gearbox, Nistune (e85 Fuel).... was hoping for 300rwkw, maybe full boost around 3500rpm. Which seems to be a fantastic package, especially with that off boost and 'transient' response the BW are known for. Can anyone speculate on results of the TS 6758??
I know everyone totes the 7163, and I do love it, was considering in T4 TS version... however I just think I'll end up netting ~350rwkw which I just don't think is useable in an s-chassis.
"slow is smooth and smooth is fast" - some guy probs a while back.
Agreed that housing is more compact in everyway. My boost solenoid (8374) is out on the edge of the compressor housing as well. While mine fit well like it is, I bet the 90 degree is a better fit with piping.
Gcg got back to me and said they can get them in for the 6758. Not sure on other sizes. They don't carry them as they're brand new and don't have any on order yet. But maybe email them if anyone is interested in converting over.
these new BW 90 degress housings? Seems like would make pipe layout on an SR20det (S15 in my case) alot easier.
agreed- for SR20 s-chassis that 90 degree housing B1 turbo posted above can help clean up pipe routings. They are much more expensive housings however
for the bigger 8374 and 9180 turbos, these already come with an optional vband you can add a 90
I have not tried the TS6758 but I agree it may be a perfect combination for what youre considering. You can use it with the 90 degree housing I have a beater S14 with SR20 and was running an old 6258. it works so well on a junk setup for 350hp that i dont plan to change anything
Holy smokes is that really 630 whp on PUMP GAS?! Well I'm hoping to hit my target of 550 whp on pump gas.
yes that is pump gas, on a built/prepped RB30. 550whp seems reasonable if the wastegate actuator is properly sprung and everything is in order.
Geoff, does full race have these in stock?
We stock the entire line of EFR turbos, the 90 degree comp covers are en route to us
AFAIK, They've only released the 90° housings for the 6258, 6758 and 7163...
100% correct. 8374/9180 already have a vband outlet that can serve as a 90 addition easily
Can't believe I have this turbo and didn't notice that? Do you simply machine off the end and then use a 2.5" vband? Does someone sell a 90 with flanged connection already?
I'd really interested. My piping does fit well but it is all silicone. That outlet really gets tight near my shock tower.
  • Like 1
yes that is correct @harrisracing -- cut the end off and its a standard vband. the same as any Cummins/Holset turbo and many other BW or MHI turbos. There are cast 90 degree vbands available for this application but you could also just but a vband and weld the intercooler pipe to it
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
