I haven't driven yours. I only used no more than 50% throttle and no more than 5500 RPM absolute tops.
It's imediately back on pipe. Makes the precisions between gears seem like a mid 90's turbo.
A dyno sheet won't give you a good idea of how it goes about its thing. That's what every owner of an EFR talks about.
How does it compare to the TO4Z you drive a while back?
Speaking to a local turbo guy and he said he can mod a Zed to bring it on 800rpm earlier, make more powa, and improve the already good part throttle transient response. Not sure if its an exaggeration, but interested to hear ur thoughts.
He also mentioned these EFRs and SXEs are very very good.
[emoji2] [emoji2] [emoji2]
Edited by XGTRX
I didn't drive it mate. I was only passenger. The Z for what it was performed very well. Considering stock engine, open scroll... Realistically a basic setup. The Z was cracking gates at 4500 rpm in second gear, to be doing that at 3700... I doubt it.
This car had -5's removed and 8374 1.05 bolted in place. I can try and explain how it was. Put all the theories and "I believes" out of your mind and drive it. It's the popping around, doodling around and gear changes that was most impressive. "Big laggy single", think again.
Stop making me want to flog off all my gtx twins bits and making me want to buy a 7670 guys...
There's a guy selling an EFR7670 in NSW somewhere.... comes with high mount T3 manifold for SR20.... but still... $2800 I think. PM me if you want details and I'll try find the link.
In all honesty Pete you'd be MAD not to! A 7670 with 1.05 rear on your car would shit 400kw in and be all in at well under 4000rpm!
Your GTX's WILL NOT do that!
Nor will they have that zing under your foot or the transient response the 7670 will have!
If i ever pull my finger out and finish the evo off. Im pretty confident my stock 2L with mivec will be making full boost by at least 3800.
If you are honestly thinking about it Pete sell up now mate and jump on an EFR you wont regret it! I been on Pauls case for ages about EFR's he and his mate saw the light and now look how excited Paul is after his 1st taste of EFR goodness. Paul and I have been spoilt and have been in and driven some pretty epic cars and for us to be this impressed means its DEFINATELY something special! ?
You guys inspired me. Pulled the wastegate hose and ran a log. Check my build thread 2.75L stroker. Ported head, ss .5mm valves Tomei poncam A, hypertune V2, stock fmic
10 psi 3300 rpms
15 psi 3888 rpms
20.5 psi at 4105 rpms
6boost manifold
8374 EFR .92 IWG
This is on medium wastegate cannister at 3 turns in (can go more and likely get in boost quicker).
Third gear
Car is barely tuned so far (I'm doing it).
Haltech isn't controlling boost though :( I'm pretty sure it's all setup right)
So, theoretically speaking here of course,....
How would one go with the 7670 .92 iwg split t4 rear on a 2.8 stroker with 260 cams?
Who's manifold would you use for that?
Hypertune do a low mount TS T4 manifold for an SR20det.... so I imagine you could get one for an RB. That's what I want 'eventually' with an EFR7163 attached.
They don't. I spent a fair bit of time with them trying to get them to do one. No deal.
Pete (from Hypertune) said they have just started making a high mount manifold for the 2JZ boys. RB's are next. Late next year if you're lucky.
Those cast collectors are amazing though.
I have the 7670 1.05 TS on a measly old RB25. The turbo kills it on a RB25, would hate to see what it does on a 2.8.
I'd imagine it's a little too small unless your car is 100% street driven.
It will also top out at 400kw..don't expect it to go too far north of 400kw even on E85.
Would probably try get someone like crg to knock one up. Iwg would make it easy enough to fit
A good 400kw would be more than enough, But track time would be had.
Are these too small comments based on 'well you could make even more power' or on the turbo falling way out of range resulting in a dangerous amount of heat
It's getting outside it's limit.
Mine makes 375kw @ 24psi on E85.
My car is with my tuner this very moment having stiffer wastegate springs put in (currently only running the supplied 7psi springs) to see if we can crack 400kw.
I'll know this time next week if it can go 30psi and over 400kw!!
Have a read on the evoM forum.
http://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/533438-new-bw-efr-turbo-thread.html
That's the link to the EFR thread. Start reading from page 100 or so. Pretty stout thread!
is that motor still stock since the day you've bought it?
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
