I cannot see why people are still using twin setups. If garret cannot develop a rear housing for their gtx twin range, means to me that the problem is with the rear housing. It nearly cost me an engine in 6min of track time.
The setup that Piggaz is referring to is mine.
All I can say about the setup is that I should of done it earlier and not bothered with twin -5's.
IT'S FCKN AWESOME in all areas. Just do it and you won't look back.
  • Like 1
The BW EFR turbos have a speed sensor that you can install on them to measure the rpm of the turbo. They have upper limits of course. There's a pretty fixed relationship between boost, speed and airflow (from memory, don't scold me if i'm wrong!) so it helps with safety and getting a good handle on exactly whats going on in your setup
The exact same one that sits on the back end of -5's
Ok, but that was made in the 90's. Do you know why they didn't make a newer design rear housing?
With my setup, the turbo is making noise at 2000 and at 3000 it wants to rip your face off.
Boost and flow doesn't have a fixed relationship. That's why I'm maxing out at 25psi on a 3 litre. A 4cly 2ltr would prob take 30psi before maxing out.
Keeping under the speed limit stops the turbine falling off.
ah yes my mechanic did install the speed sensor for the RPM on the compressor wheel. also recommended I get one.
he said due to the lightweight material used on BW, its a good idea to keep an eye on how fast it is spinning so you don't break it!
just post the gtx turbos up here and I'll test them for you
So you can find out 1st hand how hard they will fail and prove me right about all the shit i been harping on about in the GTX thread? Of how GTX compressors wont work with factory location housings?
Garrett put these compressor wheels in their own housings for a reason mate ;)
Honestly Pete you will be making the right move taking the EFR route.
So what if the GTX wheels turn out to be a "tad better" (which i highly doubt) will the machining costs etc be worth it? The EFR will still punch holes in them from 800rpm - 8000rpm in every single way and the money spent on machining etc goes to a manifold for the single an intake pipe, a cooler pipe change and a dump pipe.
The offset in the price wouldn't be that much different (if going IWG .92) BUT i guarantee the result and the way the car drive will be 100% better!
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
