Yeah man run that -5 on the track and get us some 1/4 mile results with logs. It's an exceptionally hot and humid summer here this year but when it cools I'll run the car some more.
@HarrisRacing - What exhaust manifold are you running, and what ID runners does it have?
Skidz - anything involving corners throws HEAPS of variables into the game which make it next to impossible to compare turbo performance
6boost IWG divided T4 for EFR. no clue on diameters but I'm sure I could ask Kyle.
24 minutes ago, mr skidz said:
Roll Racing sounds like something that doesn't require a steering wheel emoji14.png
Come next track day at Wakefield that trak-life & Yez Racing organise.. the September one is full unfortunately. $235 per car, untimed, unlimited track no sessions.
  • Like 1
I thought it was an invite to go have some fun not compare turbo's [emoji54]
Will do definitely at some stage last time I went to Wakefield in my last Gtr I ended up spending the whole day in rear wheel drive ripping skids with the gtst boys got some footage of it somewhere.
But I think my first track day in this car will be at the creek as I know the creek really well from many bike sessions I've done over the years I've only been to Wakefield once so I'd be useless there and besides my car still uses completely stock brakes they're not the greatest I think we all know that but for the most part it's just my streetcar / daily nothing serious just a fun car.
damnit  just went to get you guys some logs + videos and popped the axle out hammering around the first turn. Gets violent with the 3 wheel drive. need to change the circlip on the axle.
3 hours ago, Dose Pipe Sutututu said:
There are people with results however they can't be bothered sharing. One of those people just pulled off their setup to go bigger lol
Hey not my fault I pulled it apart before everyone asked for stats!
I just wanna go fast
  • Like 1
^^ Looks pretty quick!
Took the liberty of converting my dyno data from 10 psi and 17 psi and putting in excel graphs. BLUE lines are data associated with 17 psi pull, RED lines are data associated with 11 psi pull. Boost is in PSI, but is multiplied by 10 for scaling purposes (so 100=10.0 psi and 200=20.0 psi).
Also I believe the turbo would have made 380-385 whp if revved to 8k rpms on the 11 psi pull...I was hesitant at first because this was literally the first dyno pull. It did make 371 whp at 7600 rpms though.
  • Like 1
I'll get another dyno run done on this pump tune of mine out of curiosity , as my first dyno tune was over 1000rpm laggier than my current tune at 18psi when set to 25psi.
(Someone else tuned it as we needed load on the fresh engine)
Cool vids too I enjoyed watching them all
[emoji4][emoji108]
Hi :)
I have a question, what power can make 7670 1.05 on RB26 forged + cams + pb98? With no exceed 27psi?
Previously i wanna 8374 .92 but i look on HarrisRacing 2.75l RB and i think it be too laggy for stock capacity and daily drive. 7670 1.05 should spool 300-400 rpms faster?
I just need 630 EU hp on crank :D
If going 7670 I would stick with a 2.6L and stock cams. Turbo will be at maximum speed for sure and you will need to add a road rage gauge to make sure you don't destroy it from overspinning. I wouldn't suggest running the boost over 20 psi over 7k rpms. I bet it will *just* make your HP number though. It would be a VERY fun daily driver.
Reason why I say stock cams is because you will start to choke that turbo on top end on the exhaust side and larger (ie-overlapping) cams will only make the backpressure contamination worse in the cylinder.
When I was comparing the 8374 to the 7670 I think I found that the 7670 should hit full boost 500 rpms sooner than the 8374 and make similar power up until around 7k where the 8374 will continue to feed the motor. Of course I was probably looking at 2.75L at the time so I'm sure a 7670 on stock cams and 2.6L is a good choice for a street car that occasionally wants to turn up the boost.
33 minutes ago, Snara said:
Hi :)
Someone might be able to correct me if my math is wrong, but @ 27psi, but that turbo is going to be out of the efficiency range for your setup.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
