I now have r34 4pots :D
pulled the olive out and that was all the modification needed
still have some air in the system somewhere tho :/
anyone know if there is a bleeding process for the abs? (older abs like32 my had have bleed nipples on the actual unit)
got my Nismo ECU today!
What is it? A replacement stand alone ecu like a pfc or a standard ecu with a daughterboard and tunable chip? Straight plug in or wire in? Sounds exciting!
Its a complete replacement, standalone ecu. Not tunable, its just a 'nismo knows best' sort of case. Should just plug straight in (Judging by the images Ive seen of it compared to the standard ecu.. its the same size/shape).
Won't it have to have a daughterboard or something in order for Nismo to tune it? There must be something along these lines or they've just put a sticker on it and it's the same tune we all have.
maybe the daughterboard.....but it not just re stickered .... have just taken the Haltech piggy back off and run it with both the standard ECU and Nismo ECU.....the are definitely different. Am going to get it run up on a dyno next week to show the differences with my set up......IMO I think the Nismo would be awesome with the standard turbo.....will find out later tonight how it goes with a standard turbo maybe.
That's what I thought, it has to have been modified in some way to tune it. What are your seat of the pants feelings regarding the differences? I guess it's hard to tell if there's more timing other than if it's pinging. Does having this help SAS at all? Surely they would already know how to put a daughterboard in and would know how to tune it? I can't see where the hold up is with this, can someone explain to me as I'm obviously missing something. Not having a go or anything I'm just curious where the difficuluty lies with this whole re-flash thing.
Seat of the pant's = more progressive midrange application with boost...instead of the peaky shit, light footed response better, shift better, 6,700rpm limit. Like I said before I am thinking this will be a better unit for the stock turbo...will let you know later on tonight how it goes.
SAS will get the tune and have promised me a tune ASAP on delivery....hold up is the delivery of the programming unit.
wound up the rear left about a cm due to scrapeage of rim + coilover <_< rims are too wide... they're already sitting flush, so don't want to use spacers... may have to sell them off and get something else a half inch narrower :)
+ front window tint :laugh:
what shade did you go on the window tint josh? darkest legal? just wondering how it looks against the stock rears shading.
Started fitting Series 2 R33 rotors and calipers to the Stagea today. from 16mm thick to 18mm thick and Sumitomo twin piston calipers replacing the 1 pot calipers. Used pads in it for now until I order some QFM this week. Finishing off the install and bleeding tomorrow.
Then next weekend fitting 297mm rotors and 4 piston Sumitomo calipers ... and ordering some QFM pads up front too. :)
All purchased (not inc QFM pads) for under $150 (and some labour). :D
My wife and I just bought a 2003 Mini Cooper S for her to use as a daily. That means the Stag is no longer a daily driver and I can do what I want to it. Hehehe :(
Oh, another positive... it turns out the Mini has a John Cooper Works kit which boosts power from 120 to 155kw :) Previous owner must have spent a lot of money on it. Kit includes exhaust, supercharger, cylinder head, air box, injectors and remap. Bonus for me. The down side is that I'm overseas and the wife picked it up yesterday, so I'll have to wait 2 weeks til I can drive it.
Fitted Tein master wagon rear coilovers, Apexi adjustables coilys to the front , Sorted my squealing brakes .
Took it for MOT ... and had forgotten to put the CAT back on ... Failed on emissions ... Div.
I now have the fantastic task of removing 2 snapped bolts in the cat so i can fit it again .. Great.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
