I now have r34 4pots :D
pulled the olive out and that was all the modification needed
still have some air in the system somewhere tho :/
anyone know if there is a bleeding process for the abs? (older abs like32 my had have bleed nipples on the actual unit)
got my Nismo ECU today!
What is it? A replacement stand alone ecu like a pfc or a standard ecu with a daughterboard and tunable chip? Straight plug in or wire in? Sounds exciting!
Its a complete replacement, standalone ecu. Not tunable, its just a 'nismo knows best' sort of case. Should just plug straight in (Judging by the images Ive seen of it compared to the standard ecu.. its the same size/shape).
Won't it have to have a daughterboard or something in order for Nismo to tune it? There must be something along these lines or they've just put a sticker on it and it's the same tune we all have.
maybe the daughterboard.....but it not just re stickered .... have just taken the Haltech piggy back off and run it with both the standard ECU and Nismo ECU.....the are definitely different. Am going to get it run up on a dyno next week to show the differences with my set up......IMO I think the Nismo would be awesome with the standard turbo.....will find out later tonight how it goes with a standard turbo maybe.
That's what I thought, it has to have been modified in some way to tune it. What are your seat of the pants feelings regarding the differences? I guess it's hard to tell if there's more timing other than if it's pinging. Does having this help SAS at all? Surely they would already know how to put a daughterboard in and would know how to tune it? I can't see where the hold up is with this, can someone explain to me as I'm obviously missing something. Not having a go or anything I'm just curious where the difficuluty lies with this whole re-flash thing.
Seat of the pant's = more progressive midrange application with boost...instead of the peaky shit, light footed response better, shift better, 6,700rpm limit. Like I said before I am thinking this will be a better unit for the stock turbo...will let you know later on tonight how it goes.
SAS will get the tune and have promised me a tune ASAP on delivery....hold up is the delivery of the programming unit.
wound up the rear left about a cm due to scrapeage of rim + coilover <_< rims are too wide... they're already sitting flush, so don't want to use spacers... may have to sell them off and get something else a half inch narrower :)
+ front window tint :laugh:
what shade did you go on the window tint josh? darkest legal? just wondering how it looks against the stock rears shading.
Started fitting Series 2 R33 rotors and calipers to the Stagea today. from 16mm thick to 18mm thick and Sumitomo twin piston calipers replacing the 1 pot calipers. Used pads in it for now until I order some QFM this week. Finishing off the install and bleeding tomorrow.
Then next weekend fitting 297mm rotors and 4 piston Sumitomo calipers ... and ordering some QFM pads up front too. :)
All purchased (not inc QFM pads) for under $150 (and some labour). :D
My wife and I just bought a 2003 Mini Cooper S for her to use as a daily. That means the Stag is no longer a daily driver and I can do what I want to it. Hehehe :(
Oh, another positive... it turns out the Mini has a John Cooper Works kit which boosts power from 120 to 155kw :) Previous owner must have spent a lot of money on it. Kit includes exhaust, supercharger, cylinder head, air box, injectors and remap. Bonus for me. The down side is that I'm overseas and the wife picked it up yesterday, so I'll have to wait 2 weeks til I can drive it.
Fitted Tein master wagon rear coilovers, Apexi adjustables coilys to the front , Sorted my squealing brakes .
Took it for MOT ... and had forgotten to put the CAT back on ... Failed on emissions ... Div.
I now have the fantastic task of removing 2 snapped bolts in the cat so i can fit it again .. Great.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
