Get some neg camber on that sucker - STAT!! 4mm different offset than mine (+22) and your's is full mexican!
I fitted my bluetooth adaptor for the headunit, so now I can take and make calls without worry of getting busted on the phone.
i will hit the coilover soon enough if i put too much in... its got like 1.5 degrees now so NOTHING... just lipped the gaurds more and not touching at all anymore :)
they were +30 with a 5mm spacer.
So that confirms the ideal M35 fitment as 9.5 +35 offset.
Oh and they look insane! so tough!
come again?
if they were +30 and he added a 5mm spacer, that would mean that they are now sitting effectively at +25
or if they are +35 with a 5mm spacer then they would be effective +30
etc
finally got around to aligning mine, and very happy - exactly what i wanted (well maybe closer to 3 deg neg on front but 2 is fine) :P
18x9.5+2
18x9.5+1
front -2 deg camber
rears -.5 deg camber
how the driveway go mike?
yeah not too bad, no dramas getting out and only a little bit of rubbing from the front bar getting in surprisingly.
the wheel aligners was another story.. had to have a couple of blokes push me up their driveway cos i got beached sea-sawing :ph34r:
I accidentally bought some wheels when I went to get a fresh set of tyres... 19x9.5 +35 with 5mm spacer on all 4 fit peeeeerfect.
I will get some better photos soon.
NICE!!!
might have to do my headlights soon!.....once I stop buying other parts!!!
LOL @ "accidentally" bought new wheels...
lol I just accidently bought a 15g R33 GTR
going to sydney soon to pickup
must sell the track car now
currently fitting wilwood brakes, to put the brakes back on the r32.
might end up selling the stagea if I enjoy the gtr too much. or vice versa
Well it seems I need a different loom and a relay of some sort. :D
do you mean you're putting in the little motor that helps close that last little bit or the one where you push the button and the whole tale gate opens and closes?
if its the latter, where did you get it from and how much? i like gadgets :P
Well it seems I need a different loom and a relay of some sort. :wub:
If you can get a part number (and a picture) for the relay i have a box full of relays and resistors and other odd little electrical boxes left over from my wrecked car!
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
