While I'm waiting for my R34 brakes to arrive for the Stagea, I decided to remove the passenger mirror and hunt for any rust coming thru. Found some just starting and decided to rub it all back and treat it so it won't spread.
Two more weeks until Time Attack ... so in two weeks I'll need to fit the R34 brakes, braided lines, bleed the brake system thru with fresh DOT4 fluid, oil change, filter change, O2 sensor change, and a dyno tune.
:banana:
:banana:
took me about 3 or 4 hours to slowly cruise through my r34 brake swap
pull the restrictor out of the 34 brakes and use your existing banjo bolt with both original copper washers without modification
the 3-4 hours also included going to get more brake fluid and bleeding everything twice and taking the master cyl out cos i got air in it
the thread on the stock rotors (to pop them off the hubs) is metric fine pitch, cant remember what size tho
Jason it`s a simple thing to do ok not hard mate at all ,front Rotor`s slotted may be RDA954S,& EBC DP1671 & there Black stuff ,you can look at yellow stuff your call,
Now all this about then not fitting ???? ,LAST TIME I WILL SAY THIS OK
I FITTED THEN NO MOD`S OK,
Searched and searched for rotor and pad replacement for S2 stagea!!!! Read through all 19 pages of stagea brakes! Waiting for response on hpx pads. Just been on Bendix site again.
http://cgi.ebay.com.au/QFM-Street-Track-Br...=item56376b982c
they are also a site sponsor here, dont get the ar1m or you wil chew through rotors if your not getting them hot enough
ask them about the hpx's
and if you get them through sau they are cheaper
Fitted a boost controller today, Blitz SBC R. I don't believe the difference it made to the low end response, it seems to be on boost all the time now. :)
I checked the wideband higher up in the revs and it is running very lean, with a lot more punch. I had to drop the boost back down to a reasonable level until I can get to the tuner.
Wideband reset, torque converter lockup and petrol primer for starting on ethanol. There's still heaps of room for the ejector button though. :)
Stainless buttons are from Jaycar, they come in momentary or latching and are led backlit. (blue green and red.)
:D
You got that in in a hurry!
(all those wires along that side made it too difficult to mount the buttons?)
"it seems to be on boost all the time now." - Statement to make Jetwreck more envious by any chance?
very pretty Scotty....red is gay though!!!!!!could have at least put some pretty screws there.....should have done the carbon fibre look ;)
only kidding bud....looks gay but good :P.....not that gay is a bad thing :)
Cam, might be envious of instant boost but at least I have some real boost all the time :P.......that's the only comeback I have! :D
Turned up last night, had to get it in... :D
How did we go with the exhaust leak mate?
Exhaust manifold. Have yet to rip the heat shields off to have a look, certainly hope I have not sheared a bolt/stud... although that would be an easier fix than if the manifold is cracked.
Cam, might be envious of instant boost but at least I have some real boost all the time :banana:.......that's the only comeback I have! :D
"Real boost" all the time? Oh yeah?... well... erm... (stupid f*ck'n exhaust leak) ;)
EDIT: Suppose I should actually contribute here.
Okay, well a couple of weeks ago I installed my lovely Nismo exhaust in leu of the Fujitsubo Legalis. Same design, different muffler lol
On Monday night I decided to change the aerodynamic abilities of the rear end of my car by installing a stealth black trailer :banana:
Edited by iamhe77
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
