Nice tailgate window wing Mike. We were talking about these in the rare stag parts thread a few months back LOL.
Now just get some ganador mirrors on that PHAT RS! Sitting and looking very decent IMO. :P
damn that bottom under-window wing looks great!
attempting to fit longer wheel studs - wrong knurl size!!!
M12x1.25 50mm long studs with 13.75mm knurl wont fit
going to try 12.75mm knurl
expensive $100 mistake :)
Tangles, try the 50 mm nismo long hub bolts -I think 13mm, should solve your issue. You might also need longer open ended lug nuts.
Edited by dirtyRS4
cheers, i have thought about ganadors but i picked up some LED turn signal mirrors for it instead, just need to get around to painting them... with everything else lol
expensive $100 mistake :P
Did you try front and rear? I was surprised to find they are different sizes per end.
BTW careful with the attessa controller, don't use 2wd mode if it has it
Put my r34 rims on and freshly resprayed rear dayz bar.
(Actually did this Sunday morning around 1 - 3am after moving house,
car was at panel beater all week...stared at the rims in my garage for
5 days before i could fit em)
Got a dolphin (copy) grille to put in tonight, will post some pics.
Had a bit of a mild shift kit performed on Friday, learning curve over here as no-one really knows anything about the 401b boxes in WA :D
Ended up removing the 1-2 and 2-3 accumulators and replacing with welsh plugs, has actually made a nice difference. It's not really harsh and it just gets in to gear now, high rpm 1-2 change is still a little slow but it actually goes in without having to lift the gas slightly or bounce the limiter.
Also confirmed that when I put it in to 2WD mode there is NO preload in the transfer case.
With VCT working, it will now actually spin up in the dry on the brake (wouldn't even do it in the wet with no VCT).
Nicer 1-2 shift means it easily hit 2nd gear while doing a standstill.. could probably have hit 3rd if I wanted but it's only open centre for now..
2WD mode + nicer 1-2 shift makes for some interesting times in the wet :)
Next step is shim my old 32gtst diff up and throw it in, also getting the adjustable rear upper arms that were destined for the 32 fitted within the next 2 weeks.
Then it's on to Nistuning and sourcing some swaybars :D
Where did you end up taking it for the shift kit?
The previous owner of my Stag took it too Precision Automatics for a full, not soft rebuild. Shifts stupid hard even when putting around at 20km/h!
Global Automatics in Bibra Lake, I would probably call it a Stage 1 kit for marketing purposes.. on the hunt for a 34GTT box and I will loan it to them to sus things out in regards to shifting even harder. Could have spent more time on it but it's my daily and it seems nice for now.
Can take you for a drive if you want :)
/\/\/\/\ hells yeah i live in yangebup and that sounds exactly what im after, how much was it? i have a series 1 though so the box would be different.
Series 1's are just 401a (R33 and earlier) boxes and he can do whatever you want to those.
Series 2's are the 401b (R34) boxes and he's just learning about these, mine was the first he had worked on.
I won't quote what I paid as we didn't achieve what we set out to achieve so it didn't cost me much at all.
Got two OEM Nissan keys (without electronics) delivered today & went and got them cut in my lunch break.. Will find out in about an hour if they work or not :( The sizing all matches up though. $33 per unit, plus delivery. fingers crossed, it'll be nice to not be quite so concerned about losing my keys :bunny:
nice RS4S.
I got a 36mm socket to take off the rear left hub. Got to get it off to replace studs and foot parkbrake pad.
Cant budge it, phark! Letting rusteze soak overnight on the hubnut, then will attack again with a 6ft breaker bar!
so damned hard to remove LHR hub.
got the 36mm hub nut off just now with huge torque (ie 115kgs of me leaning on 4ft breaker bar)
cant loosen the hub itself tho
hit it from all angles with hammer? how else to remove the hub itself? soaking in rusteze spray at the momeht
need access behind the hub so it must come off (only this one, other 3 wheel hubs will be fine on the car while replacing longer wheel studs)
must come off to install 50mm studs & new park brake pad.
suggestions?
suggestions?
Can you fit a puller to load it up then give it a hit?
thanks mate for the suggestion. Looks like thats exactly what I need http://www.tridon.com.au/Products/Product....530&P=68973
have asked to borrow one from SAU:SA, we'll see what happens.
might have to plead to borrow one from my tuner if all else fails, who has shifted waaay out to whoopwhoop land
Blizzerd, Nice looking car. Pity about those eyelids. It looks like it has Dolfin sideskirts and rear bar. My guess is that the front bar was removed for RW as the dolfin fronts are pretty low....
I've just recently details my Stag inside and out. Yet to do the engine bay. LED's in all interior lights, Phillips Silver vision indicators front/rear and put dynamat on the floor in the boot. Yet to do the rear quarters, tailgate and doors.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
