So after having my replacement engine in for a few weeks with a hi-flow on it, it is now back to a rebuilt std turbo, (my old one) with a ceramic impeller. The difference is HUGE. The hi-flow didn't come on until 3200 rpm. It was at max boost at about 3700rpm. The newly rebuilt std turbo is on boost even lower than it was before the engine was replaced. It starts coming on a 2200 rpm and pulls hard to about 6000. The car now has a Nistune and will be tuned before the weekend. The hi-flow was not for me, that's for sure. It was slower than my wife's Maxima, until it got to about 60kph, then it was doing over 100 kph before you knew it..... crazy as far as I am concerned.
I'll post up the dyno sheet after it is done.
Should have left it on and wound the boost up John like we discussed.. laggy highflow and only running 7psi means you get all the crap lag of a big turbo and none of the fun :) it was also running the stock tune so you really can't expect much..
With VCT working my highflow is making 15psi by 3500rpm and now that I don't have a hole in my cooler pipe it pulls much harder :)
Did you put that split dump pipe on?
Edited by bubba
What hi-flow were you using? My GCG highflow in conjunction with the Jaycar IEBC gave me 10psi by 2500 rev/min and 15psi about 3500.
Do you have a full turbo back exhaust?
Edit: oh Kiwi, yours is a 33 turbo so I'm not surprised yours is on song a little sooner than our 34 hiflows.
Edited by bubba
3 inch dump is on
can't really notice much difference tho
and even after replacing the turbo-maifold gasket there is still the whine on boost
turbo had a bit of play in it so its probably that
:P
if only a side exit pipe was road legal
Yess free-reving to red line while cold, peanut.
stock gauge doesn't move off its stop till about 60°C, motor was at about 55 according to ecutalk
and its not like i was bouncing of the limiter
and i run a group 5 synthetic which is pretty sticky even when cold
and its probably been done to everyones motor in jap land
Oh pippy
what can I say
as chris mentioned,your quite the variety of a bad nut
you could of atleast put up a vid of you launching down a quiet suburban street on the limiter with just a dumpy on...
Once you warmed it up of course!!!
it still had cold start idle lol
im still looking into why my car does that
i do a lot of short trips and even once the car warms up it holds the revs up for about 5 secs b4 letting them back down every time you start it regardless of whether or not its hot or cold
do you guys hate youtube or something? cos i swear that every time someone posts a vid up you two criticise the poster about something
Sorry mate but I do believe the last clown put up a video of a stagea frying the shit out of his tyres <---- Idiot
And then you giving it stick while cold <---- Idiot
Both happened to be bannan yellow wagonws to, i can see a pattern here
Back on topic ...
Changed AFM over with a loaned AFM to try and resolve why my stag hits a 5,000rpm limiter ... misfires all over the place. But didn't eliminate the problem.
I've been going thru the elimination process with:
checked cas timing
replaced plugs and gap
replaced coilpacks
replaced air filter
replaced fuel filter
replaced O2 sensor
replaced MAF
Checked all old plugs and they were an even, nice colour. My A/F Ratio meter is telling me the mixtures are rich up top. But I've touched nothing since my last tune. Try a few more things, then I'll just throw it to the tuners. Hoping to save myself some $$$ first.
On the weekend, I'm also going to check the compression in each cylinder for the hell of it.
Not sure about the stageas, but i know the 300zx has a neutral wire to the ecu that causes the ECU to limit RPM when car is in neutral, to stop engine being overly free revved.
Might be worth checking out.
Back on topic ...
checked cas timing
replaced coilpacks
replaced air filter
replaced O2 sensor
replaced MAF
That might be the most useful input I've had yet.
I've converted my AT Stagea to manual. Is there a chance something in the ecu is causing the misfire (limiting revs) because I fooled the ecu to thinking the car is in neutral so I can start it?
EDIT: scratch that ... I've had the car on the dyno twice since the manual conversion and its definitely revved past 5,000rpm without problems before.
Just had a look, pin 39 is the neutral pin. As i said, im not sure if the stageas do it but i know for certain that the 300zx's do.
http://www.skylinesaustralia.com/forums/po...087-R34-ecu.pdf
ok, lol just seen your edit
Edited by kjb_r33
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
