So after having my replacement engine in for a few weeks with a hi-flow on it, it is now back to a rebuilt std turbo, (my old one) with a ceramic impeller. The difference is HUGE. The hi-flow didn't come on until 3200 rpm. It was at max boost at about 3700rpm. The newly rebuilt std turbo is on boost even lower than it was before the engine was replaced. It starts coming on a 2200 rpm and pulls hard to about 6000. The car now has a Nistune and will be tuned before the weekend. The hi-flow was not for me, that's for sure. It was slower than my wife's Maxima, until it got to about 60kph, then it was doing over 100 kph before you knew it..... crazy as far as I am concerned.
I'll post up the dyno sheet after it is done.
Should have left it on and wound the boost up John like we discussed.. laggy highflow and only running 7psi means you get all the crap lag of a big turbo and none of the fun :) it was also running the stock tune so you really can't expect much..
With VCT working my highflow is making 15psi by 3500rpm and now that I don't have a hole in my cooler pipe it pulls much harder :)
Did you put that split dump pipe on?
Edited by bubba
What hi-flow were you using? My GCG highflow in conjunction with the Jaycar IEBC gave me 10psi by 2500 rev/min and 15psi about 3500.
Do you have a full turbo back exhaust?
Edit: oh Kiwi, yours is a 33 turbo so I'm not surprised yours is on song a little sooner than our 34 hiflows.
Edited by bubba
3 inch dump is on
can't really notice much difference tho
and even after replacing the turbo-maifold gasket there is still the whine on boost
turbo had a bit of play in it so its probably that
:P
if only a side exit pipe was road legal
Yess free-reving to red line while cold, peanut.
stock gauge doesn't move off its stop till about 60°C, motor was at about 55 according to ecutalk
and its not like i was bouncing of the limiter
and i run a group 5 synthetic which is pretty sticky even when cold
and its probably been done to everyones motor in jap land
Oh pippy
what can I say
as chris mentioned,your quite the variety of a bad nut
you could of atleast put up a vid of you launching down a quiet suburban street on the limiter with just a dumpy on...
Once you warmed it up of course!!!
it still had cold start idle lol
im still looking into why my car does that
i do a lot of short trips and even once the car warms up it holds the revs up for about 5 secs b4 letting them back down every time you start it regardless of whether or not its hot or cold
do you guys hate youtube or something? cos i swear that every time someone posts a vid up you two criticise the poster about something
Sorry mate but I do believe the last clown put up a video of a stagea frying the shit out of his tyres <---- Idiot
And then you giving it stick while cold <---- Idiot
Both happened to be bannan yellow wagonws to, i can see a pattern here
Back on topic ...
Changed AFM over with a loaned AFM to try and resolve why my stag hits a 5,000rpm limiter ... misfires all over the place. But didn't eliminate the problem.
I've been going thru the elimination process with:
checked cas timing
replaced plugs and gap
replaced coilpacks
replaced air filter
replaced fuel filter
replaced O2 sensor
replaced MAF
Checked all old plugs and they were an even, nice colour. My A/F Ratio meter is telling me the mixtures are rich up top. But I've touched nothing since my last tune. Try a few more things, then I'll just throw it to the tuners. Hoping to save myself some $$$ first.
On the weekend, I'm also going to check the compression in each cylinder for the hell of it.
Not sure about the stageas, but i know the 300zx has a neutral wire to the ecu that causes the ECU to limit RPM when car is in neutral, to stop engine being overly free revved.
Might be worth checking out.
Back on topic ...
checked cas timing
replaced coilpacks
replaced air filter
replaced O2 sensor
replaced MAF
That might be the most useful input I've had yet.
I've converted my AT Stagea to manual. Is there a chance something in the ecu is causing the misfire (limiting revs) because I fooled the ecu to thinking the car is in neutral so I can start it?
EDIT: scratch that ... I've had the car on the dyno twice since the manual conversion and its definitely revved past 5,000rpm without problems before.
Just had a look, pin 39 is the neutral pin. As i said, im not sure if the stageas do it but i know for certain that the 300zx's do.
http://www.skylinesaustralia.com/forums/po...087-R34-ecu.pdf
ok, lol just seen your edit
Edited by kjb_r33
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
