i bought a 99 RSFOURS off a fellow forum member. have not had a good chance to 'get to know' the car, but i'm pretty happy with it so far! think the first step will be getting the emanage in and tuned and work on tuning out the R&R when it hits boost - 3 gear loaded from low revs and i could just see the fuel vapour pouring out behind the car. :P
Nice, do you have a tuner yet? I can recommend Cihan (Etuner) who has done a great job on mine, or Trent (Status). Both great if you hope for the best tune.
No to the Emanage, buy Nistune supplied and fitted, save money, get same result, be happy.
don't worry Justin, it has gone to a good home - i'm sure the void will be full of EVO before you know it. The whole drive home my mind was ticking over - can't wait to get stuck into it!
will need to do some research on the whole nistune vs piggyback deal, but i already have the emanage and a FIELD harness with the car - so in terms of convenience it's probably going to stay that way. Tuner wise, i'll probably go with Chasers. Paul tuned the Wolf3D that was in my sklyline and that turned a mess of a car into a half streetable car - plus they're also on my side of town.
will look at getting it tuned again once i get a dump pipe on it, and potentially highflow the stock turbo - needs more powahh!
I figured you already had the Emanage, has Paul worked with them? If not sell it and go with his suggestion.
planning on giving the car a full detail this weekend as it's been living outside for a few years i think, starting with a claybar and working through the different lotions and potions.
my only question is, is there any specific care i need to take with the pearl white paint? i've heard that it shouldnt be polished? or is that more in reference to using cutting compounds?
You should be right with the claybar kit, comes up great.
yeh i'm not worried about that. its the restoration steps - i've got pretty much the entire meguiars catalogue of cutting creams at my disposal from ultimate compound, swirl remover, paint cleaner to polish.
i've heard that with some pearl paints, the pearl is mixed through the top layer of clear coat, so by cutting it you can actually cut back the pearl???
M35 is in the paint, mine has a clear hardcoat over everything.
pearl paint is actuall matte with a clear coat over the top of it
so just check that its clear coat safe and don't take too much off
i reckon the most abrasive you need would be the swirl remover
New brake pads woo! QFM HPX's. Quite happy with them so far. And the service was insanely good. Ordered them midday and got them next morning. OvErNiGhT pArTs yO! Wonder how much better a1's are
Do someone with an auto S1 a favour and sell them the E-manage - they can't really use Nistune. For you Nistune will be neater and better!
A1RM's will stop you significantly quicker than the HPX's will from experience... I have noticed that the A1RM's are a damn sight dustier though!
if anyone is interested www.pivotracing.com has a sale on a lot of their gear, and with the USD up around 94 cents, it's a good time to buy parts from O/S.
i just got a speed meter and a shift lamp (yeh i know, couldnt help myself). speed meter is to correct the speedo, the 19's have thrown it out - and i figure this is cheaper than a speeding fine!
Make sure you post pics of what you do to it. On the Nistune I have heard they are good also, They were still only new when I got the emanage fitted but if I had my time over I would seriously consider one. Trent at Status does them, also he does a bit of work with the Hypergear turbos so you might consider looking him up if you want a highflow. The hypergear stuff is good value and I have heard heaps of people on here claim good results from them.
got some different wheels :happy:
downgrading to 17's but they are wider and clear the r34 brakes without spacers (win)
and also 8"+35 instead of 7.5"+42
will post some pics when i clean them, they look ok but i'll get something better soon
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
