Picked up my car this morning, resplendent in new heatwrapped mid pipe, 100 cell hiflow cat, and shiny Fujitsubo exhaust fitted. Now it's 3" from turbo to tip.
Canak Autosport did a beautiful job on the mid pipe; tucked up nice and close to the floor, out of harms way. Cost a little more than I expected, but there's almost $400 in cat, flex joint and flanges.
Sounds brilliant, no drone, just a sweet rumble at idle, and nice rasp as you rev out. Now pushes almost 15 psi instead of 12, feels so much more responsive!
One very happy camper.
Good stuff Dale...
Picked up some 33gtr swaybars last night, will chuck them in on the weekend and pull the diff out to be dropped to my diff guy on Tuesday... SkidWagon is getting close.. BRING ON POWERCRUISE!
Bet that sounds shit hot also Daleo..as well as looking quite smart! *thumbs up* :O
Im actually wondering if the HKS suited for the M35 sports muffler on my full 3" system from scotty actually gives more power than the fujtsubo / kakimoto M35 systems. I know the Fujitsubo and Kakimoto's have a much nicer quieter tone. (bit like a rexy bob)
My question is would there be any difference as mine is like 50 times louder?
Edited by PetroDola
I think it comes down to the design more so than how loud it is.
Both the Fujitsubo and Kakimoto exhausts are designed to flow as much air with as little restriction as possible while their muffler setups use vastly different designs to control the sound/volume
I think that the only way to tell if yours makes more power would be to dyno them back to back on the same car.
You can't look at Scott's dyno results for a comparison between the two because he changes shit on his car every second day :O
Edited by iamhe77
hrmm good Point Iain.
Im wondering if scott has any dyno's done with just that exhaust mod from stock :huh:
and what impact it had...would be interesting to know the difference for sure.
Cheers!
Had the 260RS profesionally detailed today. Got the lot done for $300 which I recon is bloody cheap! Then brought it home and polished the GReddy intake pipes. Man I love this car even more now!! :)
A bit lame but bought some 15mm hubcentric spacers from JustJap.
Matt@JustJap had them delivered to my door within 3.5hrs (ordered 10.15am sitting on the doorstep at work by 1.45pm). That is outstanding service and deserves a pat on the back.
I have a HKS2835ProS going on next week to replace the perfectly fine HKS GT-RS which will be a more interesting mod. More on this next week.
Im wondering if scott has any dyno's done with just that exhaust mod from stock :D
Cheers!
I asked for the system to be fitted when I bought the car so no pre graphs, I cant even remember what it drove like... I think the words were "4 cats, you are kidding right". :blink:
Cheers!
Im pretty sure you replied to Cam's post and not mine mate :P
its not like we are remotely the same, he has a gay coloured car!!
lol... and you have a stock kinda car (or is that a "gonna" kind of car :laugh:) with an old-man interior!
Anyway, minor-ish service on my Stag today - oil, cleaned intake and a/c filters, changed plugs etc, etc...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
