Gave the stagea some love
Gw m5000 sougi, new filter, flush the attessa and transfer case and new detron 3 for it
Those drain plugs are in there tight as!
O,h and also installed my cruise control :blink:, bit of an effort but should be worth it
Bought my Stagea a new windscreen...
And I haven't even driven it yet. (still at compliance FFS)
:(:blink:
how did you go with the windscreen? who did you end up going with? and happy with job?
OK so the nismo ecu will take some getting used to. its got a HELL of a lot more bottom end to mid range power. its been pouring with rain and i had the mrs in the car so i couldnt test full throttle :blink:
tomorrow ill take her for a drive after i reset it.
might even put in the instrument cluster!
nice andy and Iain! - take em to the track !
rips the actuator hose off .. lets see what 25psi does! :D
btw .. hit my first gutter in the nismo's the other night.. nearly had a heart attack..only put a small cut in the lip of the tyre and a tiny bit of lip rash on the rim..more scared of hitting curbs than i am of blowing a turbo! :)
Edited by PetroDola
yeah done the gutter thing before, sucks doesnt it?
to the track? hahah not yet! need to get the transmission looked at. i think with this additional torque, the gearbox wont like it :D
did the ecu idle learn. perfect. 650rpm down from 1000-1100 odd :)
Hanso - i'll be doing the same in preparation for the 28th and leaving the stag in the carport
just won a boot mat for the M35 for 67$ plus shipping.. be like $150.. theres 3 left for 80$ on importmonster with 20mins to go.
get in der if your chasing one!
Edited by PetroDola
I finally got around to washing & polishing my Stagea for tomorrow's SAU QLD Charity Cruise. I hate parking under trees at work, FTL.
Likewise. Got out the cut and polish after the wash indicated how poorly other people park/open doors :ermm: bastards.
bought a ring for my soon to be financee
Return it while you still can... :ermm:
Or make sure she gives you an equivalent amount of money to spend on yourself or mods for the car!
Packed the stagea up to the gunnels, just about to get on the boat for the mainland :banana:
then 2-3 days of driving and will be back in qld at last
also washed it b4 the trip
fitted up my 3 inch cat back this week. RBD2's old front section and a fujitsubo rear cannon.
flows so much better, just need to adjust the position at the rear.
well this is true,....
but one of the guys on the other forums i am a member of is planning to fly over to WA to check car out and leave a deposit.
so thats atleast 6 G's i will have
1 G will be like sup dawg
the other 5 G's will be chilling back with 40's
nah but in all seriousnessnessness, 1200 back to parents and then a good service/dyno/new pc for stacy, and a Intercooler
and then she can have the rest to put on my loan...
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
