Karl Heinz Urban:
In son of rajab of the Rings played Éomer was adopted together with his sister, Éowyn, by King Theoden of Rohan when their parents died.
Also was in Star trek (2009) and Xena: Warrior Princess (1995)
Same 2.5 litre V6 as the 626, beautiful engine, but when they go wrong; and they do... BIIIG dollars.
i think you will find the Eunos 30X had a 1.8Ltr V6........ we used to own one back in the day when we were in NZ.
Right you are :thumbsup: , the 2.5 didn't have much torque, that 1.8 must need a rev to get going...
Has anyone seen the movie "RED" with Bruce Willis, Helen Mirren, Morgan Freeman and John Malkovich in it? I was watching that and noticed that Jetwreck has a doppelganger in one of the other major roles...
http://www.imdb.com/...08928/tt1245526
http://www.imdb.com/...19040/tt1245526
http://www.imdb.com/...97696/tt1245526
http://www.imdb.com/...66112/tt1245526
Damb....Iv'e been sprung again!....not the first time someone has said that.....apparently I was the Russian Bad guy in The Bourne Identity that died in the car accident as well!!!
Just wish everyone would get it right....he looks like me not the other way around....I was born first!! :P
Edited by Jetwreck
Karl Heinz Urban:
f**k that shit. He was the DOOM GUY!!!!
Gutted! It looks like I have to go to Sri Lanka for a couple of weeks, leaving on Tuesday... so not only do I miss the opportunity to demolish Robbie on the dyno, but Ryan will probably have his sway bars in before I get mine! Bastards!
your sri lankan?
can i go instead??? lol
:rofl: Mate, Im as white as can be. I find meat pies a bit on the spicey side sometimes :P We (my company) have an office in Sri Lanka, and I oversee some projects that are run out of that office; so Im needing to spend some time there to get a few things finalised :(
damn u.
lol i find some chillies as mild as a meat pie!
i havnt been to lanka in ages! wanna go back :(
Went to a different BP to my standard local, and the attendant was so excited by my car he just about had kittens. You'd think working at a petrol station he'd see a lot of quite nice cars coming through, but he seemed to be compeltely enamored by my stag; he knew what it was - and basically ran out and said "Man that is awesome. That is just cool". Kinda humbling to see someone so enthusiastically positive about your pride and joy :rofl:
Haha atleast when you fill up you don't get yelled at by the caltex attendant saying "no no don't put ethanol in your car it won't work I don't care what you say" true story happened today lol
I should be so lucky. He didn't even offer me a discount on the fuel! Mustnt have liked the car THAT much.
what a sham! he probably said that so youd fill right up.
AAron, thats gold! did you spin all 4 wheels right out of the station to show him that you CAN put E85 in your car?
Well I sure showed him! I only filled up half a tank; $1.60 was just a touch too much for a full tank.
And LOL.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
