  • Replies 47
There are no kits available. It has to be all custom fabricated and setup. Its not a popular or simple setup either. Parts are expensive and the system takes up alot of room.
At a guess if a workshop was to do it all, I would estimate 20-25K would pull up alot of the parts and labour including fabrication and machine work. But that wouldnt be including alot of the support systems needed.
Expensive to do, but the results are well worth it from what ive seen.
yeah it can be done, but expensive and lots of custom fabrication
you also have choice of what goes first, turbo or super into the intake
i think stockymystock has a rb30 twin charged, turbo and super from memory
from memory on his he had the super going into the intake after the turbo
so when on take off the supercharger would suck through the turbo winding it up quicker
intake -> turbo -> super -> plenum - i think stockymystock had this (macgyver is his user icon on here)
or
intake -> super -> turbo -> plenum
Yeh thats how his was setup.
Worked very well! The power delivery was insane. No lag and power all throughout the rev range. I was fortunate enough to have been taken for a spin in it!
His car is what initially got me thinking about supercharging and twincharging.
the key thing though, he did it all himself :D
paying workshop rates for that, forget it.
Exactly! Hence why my rough guess was 20-25 grand. Ive done the suprcharging half of my own car and its cost me about 10 grand so far in parts, though some of it was support system bits. I would guess probably 6-7grand for supercharger related bits, maybe abit more.
I just have to do the turbo side of it now, which looks to cost maybe a couple grand more. But so far ive done everything myself and thats what has kept the cost reasonable.
If a workshop is doing the job and the word custom & fabricate are used in the same sentence, its going to cost you.
A workshop that has the machinery to do it in house, probably a month or so. A workshop that would outsource the work they cant do themselves, many months. It takes time to measure, design and test fit, modify and refit then finish to be ready for final assembly. That would be working on it almost everyday too.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
