<br />100% faux port shrouding...<br /><br />...the absolute must have this summer.<br />
<br /><br /><br />
LMAO wow, ZING!
Surely its ported? Can MR owner confirm? Maybe pics lie....
haha I was worried for a second... There is an tiny slit that goes back inside the turbo, as per the picture.
<br /><br /><br />
LMAO wow, ZING!
Why worry at all, if it isn't prone to surge then surely that is good thing. The tiny reliefs should take care of any slight tendency.
I can't wait to see the results.
Sounds like a defect/EPA waiting to happen mate, really hope you don't get pulled over...
You should make 300rwkw on PULP though either way. 260 is rather conservative and a normal GT3071 will do that.
Why defect waiting to happen? Yeh 260 is conservative. Keeping engine in check. But 260 on this dyno is like 290-300 on others.
every dyno 'reads low' mate. its the new black. so pay no attention to such claims.
but you part list, is a walking EPA mate. In Vic you need to be smart.
No AFM is a 5 sec giveaway check for officers
non factory airbox is another when combined with a FMIC.
fuel rail, same deal. dogs balls obvious
then once they see the above, they already know you have ECU etcetc.
300rwkw should be almost undetected if parts/mods are chosen carefully.
I'll have 300rwkw next week... should i get defected, and given its super stealth i doubt it - it'll be in a passable state in less than 60mins :)
Where you'll haven half a day of swapping parts if not more and you stand a very high chance of getting pinned, and lead to them taking photo evidence effectively screwing you.
its just how Vic is these days sadly.
I've already been pulled over. They saw air box giant "tuned by AVO" sticker on it. Front mount. Full exhaust. BOV. Plumback of course. Etc etc. No issue. I got canaried cos my rhs headlight was hazy. He wanted to be a prick and that's all he had to pick on. Everything I've done is legal. Everything I want done. Is legal. Fuel rail etc etc. Is legal. It is not illegal to modify a car. Just has to stay within EPA. If they test my noise and emission levels I will pass. I still have a cat. I have no screamer. Apart from fmic. Outside of car looks standard. I dont have gauges or a hand controller for my ecu lol. Open the hood all is stealth and legal. Box is enclosed. I only have one intake mod. My fmic. Only issue they may have is not seeing AFM. easy fix. Attach it again. Run loom to anywhere and attach. They won't know better at a glance.
And this Avo dyno does read low. There are people on these forums saying they have 220rwk same setup as me. Running less boost. Some say they are breaking 200 with standard ecu. Exhaust and fmic.
Ive dynod 2 days apart. One at HPF. one at Avo. Temps only a couple degrees apart. Hpf read 192. Avo read 171. (before my rescent mods getting me to 191 at Avo)
I KNOW Avo reads low. The facts are: a dyno is good to see your gain. Fullstop. Therefore I'm aiming to gain about 60-70rwkw with this next set of mods. Whatever the top rwkw this dyno gives: Who cares really.
Edited by ShiftyTys
Sorry but you are grossly wrong about legalities.
I hope for your sake you don't get EPA'd. What i said above, is 100% correct whether you believe or it not (or the people telling you are legal, admit they are misleading you).
I take it you came here to learn... So when you ask for advice/input, don't dismiss it with 'i know better because that's what someone told me'.
If that's your belief then there is little point in asking for pointers in the first place to be honest.
A lot of guys here including myself have had many setups and been in many situations over the years etc. There is plenty of good knowledge here, best part is - its free. We want people to get value advice to help you. not line our pockets ;)
You can change a turbo in 60 minutes?
Rail is a modification to fuel injection system, instant fail there even if you use standard reg and injectors. Same goes for ECU, if the stock one isn't plugged in and visible, fail, if they suspect it they will unplug your AFM and see if it stalls, if it doesn't they will go looking for the ECU. You can get good inspectors and get lucky, but it has happened to people and if you want to be 100% ADR compliant you can't have those things, if you want them they will make you do a full spectrum emissions test, not just an idle one and that isn't cheap.
Edited by Rolls
Haha. Ok no worries. I won't even get into where I got my info from. We will be arguing in circles. About who's right and wrong. Also. I do appreciate info given from everyone here. Please don't get me wrong. I don't wish to offend anyone. Is there a specific Vic roads link or sumthing regarding mods. As I would like to take it to where I got my info and see what they say.
But back on topic. The new turbo should be awesome. Only problem is getting that power to the wheels. I'm getting a cusco 2 way LSD. Thatl help. But at the end on the days. I need much more rubber. Ha.
Edited by ShiftyTys
After reading the last few replies, you really should just listen to Nismoid on the legalities....your car WILL NOT be legal without having everything engineered and a full (read again: FULL) emissions test.
http://www.infrastru...n/vsb_ncop.aspx
This is what you are after, it covers everything all the relevant ADR codes which you can manually look up etc, this is what they use at regency when approving modified vehicles.
I can guarantee you 100% that your mods are not passable and if you do pass it is because the inspector is lenient and has let you off, this does happen but only for minor things, try and go through with an aftermarket fuel rail and you will never pass. I did an engine swap and filled out all the required paper work, had emissions test etc and I still had 3 guys simultaneously going over the entire engine bay, they even questioned the turbo as it had been rebuild and was sandblasted whilst everything else was dirty, they followed every vac line, checked the injectors, the colour of the label on the AFM to see if it was a Z32 absolutely everything, I am fairly sure they have 'skyline' inspectors lol, he even pulled my ashtray out to see if I was hiding any boost controller etc in there.
You specifically want to check out the engine one:http://www.infrastru...1jan2011_v3.pdf
Edited by Rolls
Vic also has plenty of additional stuff to deal withover and above that... ive been on the receive over it all many times, only reason i know it all so well, wasn't by choice he he.
Lol. Thanks for eveyones advice. I'll go with bigger injectors without fuel rail. What else do you suggest? I have to be AFMless. Do I just readd it to the piping to add a bot of an illusion? How is everyone getting away with mods. Eg how are you doing it?
Wow i just had a quick glace at the link above for vic roads and engine mods. Sucks to be u guys. There a$$holes. Must be run by greenies
Your telling me. It's getting to the point where's it's just plain stupid. I've done everything pretty stealth I thought. Now that I've bailed on the fuel rail idea. Only issue is AFM. What do I do about that?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
