Has an AVO HD actuator, i would of thought it would be sufficient..
Trent is a magician and if there is a problem i reckon he will find it but , is it wrong to say that there is every possibilty that this is just the nature of the turbo as AVO have said..
you can see in the second photo the actuator is rated for 12psi.
with my GT3076R 'highflow' (45v4 Nissan ported comp.housing, garret chra, avo .73ar 6-bolt skyline exh.housing) I originally had a 12-14psi adjustabel HKS actuator.
Wasnt happy with how it came onto boost and spooled up to 1.1bar, sold the hks actuator and installed a 18psi garrett actuator, seemed to make a slightly better difference in how the turbo performs overall. The 18psi garrett actuators sell on ebay for $120 delivered. Buy/sell and feel the difference.
Definately a thought. They are gonna sting me for labour though.
Its one of the things you should be doing yourself, it is a 10minute job to uninstall the current actuator and bolt up a larger 'heavy duty' garrett actuator.
If I can do it in a quarter of an hour, being 200cm tall with no knees and fast-fading hips, with hands on the large-side, you can shit it in easy.
http://www.ebay.com.au/itm/Garrett-Wastegate-Actuator-18-PSI-Universal-High-pressu-/370355916399?pt=Motors_Car_Truck_Parts_Accessories&hash=item563aeece6f
Wont it mess with my boost. Currently I'm assuming the actuator bails at 12psi then my gizzmo holds the rest. Wont either my gizzmo be useless, or I boost higher than my tune if I swap actuators?
I use a Greddy Profec-b spec-ii in conjunction with the 18psi Garrett actuator.
The EBC will allow you to modify the 'Gain' settings etc to bring on the boost as best as possible.
shouldnt make much difference will just make life easier for your gizmo id imagine...
Fuel pump dude? you have changed it havent you
Yup wallbro 550 nvm about.my above question. If I get an 18psi HD actuator. I Gota make sure I'm not tuned to 17 or sumthing. Wichita I think I am. Changing the actuator will mess.with that.
But your running at least 18psi right? If someones running less and they put an 18psi.actuator ones the gizzmo release the actuator will still cause boost to gain.
No, I dont believe it would be an issue in regards to the tune. Setup the EBC you have for 17psi with the max setting of 18psi.
ie I have the 18psi actuator, my EBC is set to 1.1bar and 1.2bar low/high settings, which is equal to 16psi low 17.5psi high.... I dont have an issue
(however in saying that at my last track day I broke ringlands on piston#5; oil "somehow" got onto the AFM, half a lap of WideOpenThrottle later and rings let go)
You can purchase different psi-rated actuators, I believe 12-14psi, 14-16psi, 18psi, 20psi, etc
here is a 16.7psi actuator - http://www.ebay.com.au/itm/Actuator-16-7psi-/300550937648?pt=AU_Car_Parts_Accessories&hash=item45fa3b5c30
Yeh I thinks it's safer to go slightly under my tune. 16.7 paid seems good.
The car is going to avo Monday for the day to adjust cam gears and see of the actuator.is causing issues. Then into Trent on Tuesday lol
Also that's just a generic actuator. I'm specificalygoing Garrett HD.
Just hold ya horses. Wait till Tues night.
Then worry about "where to" with regards to changing parts, more labour etc. Patience for now, there is no obvious reason to spend any more money on parts at this point.
Ill rephrase. "I would go a proper garret actuator instead of something generic" if needed. :)
I would always have the tune checked after doing an actuator change/boost controller reconfiguration. The actuator may allow the turbo to make more/less boost in certain areas of the map therefore messing with the tune.
Yeh definately. That's a given. Left it there tonight. Appears to be in good hands. Seems pretty cluey!
Here's hoping it comes back a monster!
Perhaps a definitive answer on AVO's business ethics while were at it. We can see if they really were just too lazy to do better for the customer.
Avo have been very good to me. I just want fresh eyes on the chart. Trent did comment that the boost curve looked kind lazy lol. Anyway. We'll see.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
