Buggered if I know, interior and exterior are pure RS.... maybe it has Autech suspension?
Ride height looks fairly standard (Based on that photo from the rear) - assuming 'Autech' suspension is what they throw in the AXIS it should be looking a lot more 'slammed' imho. Too odd!
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5553376
  • Replies 57
Yeah, ride height does look stock, but I don't know how much lower the Autech suspension is (wouldn't be much)... if it is at all lower than RS/RX suspension.
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5553401
about a couple of inches i think.
I've seen my car side to side with an Autech, and it looked quite a bit lower.
Considering that the Nismo S-tune is 20mm lower than RS/RX stock, I would seriously doubt that the Autech suspension is as much as 10mm lower than standard.
Garett has an M35 with Autech kit which has S-tune suspension on it, and it looked much lower than the Sage222's
Interesting. Someone want to FAST my VIN and see what it is?
6U90000NM35305300
yes
VQ25det RX Four, build date Dec 2001, no HICAS
Edited by iamhe77
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5553524
cool i do have an autech! (not that i have any idea what that means exactly) ;)
happy that in stimulated some conversation too!
does that FAST app tell me anything else interesting? I see its a build 9/03 which is nice.. the seller told me it was an 03.. tho i couldnt find any details on the car..
Does it tell me if it has HICAS?
just on another note for those following this thread.. i will indeed junk the AVIC-XH9
I am looking at putting a flytouch2 into it to replace it..
10.2" screen. GPS, HDMI, Wifi 3g, divx, mp3 games etc.. It runs Android so the world is your oyster! :down:
http://cgi.ebay.com.au/10-2-ePad-FlyTouch2...=item1e5fb47ae6
Can get cigarette lighter power for it to hard wire it in.. then i should be able to go headphone jack to RCA amplifier to feed back into the stereo.
Anyone got any experience with this?
Edited by Sage222
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5554409
Where did you get that build date from? HICAS?
Did you actually read my post and look at the attchment??? :(
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5554892
im downloading Nissan FAST now.. though can someone tell me if mine has HICAS?
i just had a look at mine again today at the dealer (still a couple of weeks away).. They had it next to a 01 non autech.
The 01 had a smaller diameter exhaust at least from the centre muffler.. also the centre muffler on the 01 was only a small unit where mine has the big molded unit..
What is factory diameter exhaust of the stagea? cause on my autech it looked at least 2.5" and the 01 next to it looked like 2 1/4".
Wondering if mine has aftermarket or the 01 does or both.
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5557291
To the best of my knowledge, HICAS only came on AR-X models. An AXIS will have HICAS if it started off life as an AR-X also. Given that the model on the back of your car is 250t RS, I'd say 'No' to HICAS. But we've been wrong about your car before :thumbsup:
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5557303
can anyone tell if the m35 shares the same springs as anything else? skyline etc? looking at a cheap option to lower it. :ermm:
350z springs SHOULD fit. Stock springs on the M35 are the same as V35 and 350z - or at least thats what I was told by Sinergy motorsports when I was trying to source springs
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5559113
I think you will find v35 are similar but much softer, not what you want when lowering. I have king springs here if you want to lower on the cheap... Are your shocks ok?
https://www.sau.com.au/forums/topic/344313-got-one/page/2/#findComment-5559128
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
