wow, who would have thought this piece of shit track would bring back boring racing
How in the fcuk are places like this and hungary allowed to be apart of the calander
Well done to vettel, just counting down the weeks until this championship is done. Kind of a shame that with the points lead he has now, he doesnt even have to win or come second to have this all locked up.
Yep, I dozed in and out of sleep, f**king waste of race weekend innit.
+1 to this.
Oh, and am I the only one getting sick of hearing "I have no KERS, KERS is gone"... then said driver immediately puts in fastest lap of the race on their next lap or two?
Lastly, DRS is as shitful a Ecclestone... if DRS must be used, can we at least have it available on corners?
6L atmo? even that is waaaay too quick.
4 cylinder sounds crap, i'm suer v6 wouldn't be that good either. inline 6 is a possibility but for packaging reasons nobody uses them in production cars any more. v8 sounds crap especially with this blown diffuser nonsense.
I'm a fan of smaller capacity V10 or V12, NA. Keep the cylinder count high, no RPM limit, and reduce capacity as required to keep power within sensible limits. Besides that I say "anything goes" with the engine as long as they still sound meaty and not tinny like a motorbike. Not really a fan of turbo, it kills the exhaust sound. V12s were before my time but the V10s sounded magnificent.
Get rid of this reliability stuff, engines and gearboxes lasting half a season etc. The random blowups used to make things interesting.
Aero needs to be simplified still further, to make it easier for cars to follow closely. That and mechanical grip needs to be improved. I think DRS has too many rules, and is a bit artificial. I have no problem with KERS because drivers are free to use it at any point in the lap.
The main thing for me is the sound. In between F1 practice sessions when the two seater V10 comes out my jaw drops and I go what... is... THAT.... :worship:
When did this happen? Lap times drop with fuel loads but I think it is safe to say that KERS makes cars quicker.
as pointless as not even putting in a time in q3? these tyre regs need the most work
from start to finish, this whole weekend has been a complete let down
Refueling would solve so many problems. Two, three or four stints where cars are driving flat out rather than circulating to manage fuel, tyres, engines and gearboxes.
Button did it last night if I recall correctly.
Also I think Webber did it a couple of times earlier this year
Fuel reduction is the main reason plus the on/off nature of some KERS modules when they get too hot.
I agree, but JB did it the lap he was heard on the team radio last night.
Whether the team radio broadcast was quite delayed I do not know.
I think you will find that those messages are delayed, have heard the commentators say as much a few times, was more than likely coincidence
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
