lol, yeah look like benneton had the blown rear diffuser back in ye olde times but I wonder if they had the ECU smarts that could make the engine produce 80% of it's peak exhaust gas even when at part throttle? that's the key as far as I know to making them really useful.
I should explain. those pics were robbed from when the car was for sale about a year ago. engine had a recent rebuild by a engineering firm of the name maclaren. not sure of it's affiliation, if any, with Bruce's mob of the same name. probably not related at all.
steve-o. these pics were taken in the last year or so but that would be how the cars were (are?) timed. don't forget this thing ran in 1988 but even still timing of cars with transmitters has not really advanced at all in that time. the tech is pretty robust and useful as it is.
lol baron i think the engine would have been the limiting factor for benetton, given what we know about their masterful engine mode mapping in the mid 90's ..... haha
And yeah, exhaust blowing techniques have been around for quite a while, its probably just now they have pulled it out of the old tech recycle bin.
Blown diffusers have been around for ages. But off throttle blown diffusers are a relatively new innovation.
According to the website it was once related, but not anymore.
Did anyone else notice there were no retirements from the Gp on the weekend. AFAIK that has never happened.
It has happened before, but it's pretty rare. It happened a few years ago, like 05 or 06... or maybe 07?
I went & looked it up. Sort of
The answer is supposedly two.
Two are Monza in 2005.
The Dutch GP in 1961.
The big news is:
Narain Karthikeyan is the first driver in F1 history to finish 24th.
FIA confirms 1.6 turbo engines for 2014
The FIA, motorsport’s governing body, has confirmed that Formula One racing will move to new engine regulations in 2014, with the current 2.4 litre V8s being replaced by more efficient 1.6 litre, turbocharged V6s.
The FIA had originally planned a switch to four-cylinder engines in 2013, but has approved the revised formula in light of concerns formalised last week by various interested parties.
“Following a fax vote by its members, the World Motor Sport Council has ratified the engine regulations recently drawn up in consultation with the main stakeholders in Formula One,” read an FIA statement.
“The new power plant will be a V6 1.6 turbo unit with energy recovery systems. This new formula will come into effect as from the start of the 2014 FIA Formula One World Championship season.”
The new energy recovery systems (ERS) will replace the current kinetic energy recovery systems (KERS) and are expected to be more powerful. Combined with the legalisation of turbocharging, they will ensure overall power outputs remain similar to current levels, despite an anticipated drop in the permitted rev limit.
Formula One’s last turbo era ended in 1988, a season dominated by the 1.5 litre V6 Honda-powered McLaren’s of Alain Prost and Ayrton Senna. The sport returned to naturally aspirated engines in 1989, with a new 3.5 litre formula
Was looking at old Jordan pics, their exhaust blew into the underside of the rear diffuser in the 90s
Yeah right you're looking at blowing the 'other Jordan' pics Mr Brisby, we're onto you ;)
Sooo, 26 years later, we're going back to 100ml larger V6's, with a reduced rev limit and better materials, what a technological break-through this will be ...
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
