One are hopeless. Cutting to ads when showing Webber's in car lap
Yep. I couldn't believe it. BBC are showing incar of the pole lap which also happens to be an Australian and faking one cut it short to squeeze in a few extra ads. Nice.
I also can't believe the fia are f**king with the rules in the middle of a season. All teams new the rules and built the best car they could within those rules. Changing the rules and enforcing that change mid season is unfair and anti competitive. If they think there's a problem by all means announce a rule change now but to be implemented next season so that everyone can design their new car with that in mind.
cjet; I think it was carbon from exhaust pipe, must have got low and close to the redbull checking out the system....
murray walker sounded Old and sick.
hoping Webber runs 1st from start to finish!
webber drops to 5th on the first lap, and fights his way back to 3rd on the podium.
ricciardo drives well, makes up 6 spots and finishes his first GP
That's a fairly likely scenario. However if Webber leads Vettel through the first lap he has a very good chance of breaking his duck this year.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
