Can any one tell me if u can choose what stands you can go in at melb gp with this 4 dayer?
Missus is gna get it for my bday and come sunday. I was in piquet at turn 3 or 4 last yr (big big right hander)
Any spost u boys can reccomend?
look back a page or 2. ivan posted one that sees you end up in the Brabham stand for race day (best stand on the circuit).
So.....BBC and sky sports coverage hey....
Yeah, great so were either going to have to pay for it or go back to the early 90's where you couldn't watch f**k all.
10 year audience high and the Beeb couldn't afford it, whoever is in charge of these sorts of decisions can choke on a cock and die slowly.
I think its great that Sky has shared rights. When they bug Bernie's and all the drivers phones...it will be great to hear what is really going on in our sport....actually rather pi55ed that Sky is now in the picture.
And the thinking was Hungary was meant to be a real RBR circuit so I had a chance-of seeing a Mark race win....doesnt look that promising at the moment. Oh well, there will always be Romanian strippers
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
