Can any one tell me if u can choose what stands you can go in at melb gp with this 4 dayer?
Missus is gna get it for my bday and come sunday. I was in piquet at turn 3 or 4 last yr (big big right hander)
Any spost u boys can reccomend?
look back a page or 2. ivan posted one that sees you end up in the Brabham stand for race day (best stand on the circuit).
So.....BBC and sky sports coverage hey....
Yeah, great so were either going to have to pay for it or go back to the early 90's where you couldn't watch f**k all.
10 year audience high and the Beeb couldn't afford it, whoever is in charge of these sorts of decisions can choke on a cock and die slowly.
I think its great that Sky has shared rights. When they bug Bernie's and all the drivers phones...it will be great to hear what is really going on in our sport....actually rather pi55ed that Sky is now in the picture.
And the thinking was Hungary was meant to be a real RBR circuit so I had a chance-of seeing a Mark race win....doesnt look that promising at the moment. Oh well, there will always be Romanian strippers
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
