......Go Lowndsey & Skaifey :cheers:
I'll drink to that. my 2 favourite drivers. they were great as a team in the late 90s and great as a team again this year winning at PI and Bathurst. not bad.
I still have a giant poster of skaife and lowndes standing in front of their 99 HRT cars with the heading "giving them the old 1, 2 in 99". only lowndes was the no1 man and skaife was the no 2 which was a feeling he didn't have very often in his career.
here's one someone prepared earlier. you may recognise it...
http://www.my105.com/ListingDetails/tabid/65/p/17/cid/518/id/3723/Default.aspx
a bit pricey though!
Edited by hrd-hr30
now that's what you call an MX5! agree it's pretty pricey when you consider an MX5 is sub $10K car, add a few grand for SR20, spend some money on bits and I reckon you could build it for less than the near $40K asking price.
Very cool, but needs a hard top !
Evil Weevil,
Having driven an NA (NA) and a R34 GT-R and then s15 turbo 1.6 NA the difference is mind blowing, once you put the little snail on the side its crazy how fast and responsive they are !
lol. probably should double the costs I guess.
Duncan spent $250k+ to come 2nd in club last year. No idea what the pulse evo was worth but even the driver (wilfred) would have cost them. I shudder to think what the cyber evo has had spent on it....maybe $1m is right?
How long have Cyber been developing the evo for?
Not sure where $250k came from!! Ha ha. I doubt Kalis spent six figures on his eve to win.
My car cost $167k drive away, mods for that event included tune and tyres (didn't run the wing due to carbon boot, however carbon bonnet is apparently ok..). Anyway the r35 was acquired to run in sprints, wtac was fun but a secondary event for me. Would love $250k,... surely enough to win open.
ok if someone has 250k here is what I reckon you should do with it.
  1. 70k for a race only import JDM R35
  2. 35k on built 4.1L bored/stroked built engine and AMS turbo kit, good for 800 awhp easy
  3. 3k on COBB Access port and custom tuning
  4. 10k suspension (3 way MCA adjustable setup and front/rear control arms/antiroll bars)
  5. 6k brake upgrades
  6. 6k cooling upgrades
  7. 10k on stripping interior, plexiglass and roll cage
  8. 20k chinese carbon hood, doors, fenders and front bumper and active rear wing
  9. 10k for 18 inch custom light weight forged wheels and 2 sets of RE55s
  10. 5k on transmission strengthening
now my maths is rubbish but I reckon thats about 175k spend for a car that would be more than competitive in open class and with the help of a driver with some talent would go sub 1:34
then you could take the other 75k or so and fund 2 years of track days in your local whatever comp or throw a massive party after superlap with all the models and your mates.
done.
anyway thats what I would do if I was single.......
Edited by handbrake
lol you round down, I round up.
Either way, $175k is an expensive cost for the entry level class of a supersprint. And I reckon I'm not far off what it costs to run Open or Pro either.
Mark, I like how you think. But there is no doubt that get down to supertaxi speed requires more engineering than just bolting bits on a car.
I don't think you need $175k to run 1:44's at EC. But, you'll need to take on much more compromise vs the everyday drivability the gtr offers. That's the whole point of the r35.
At any rate the biggest constraint with clubsprint relates to tyres. I don't see six figure mods overcoming this.
I agree, coming from an engineering standpoint I can think of ways to EASILY spend 500k on a race car.
Remmember Gibson were spending atleast $1000000 building the 32's back in the early nineties...
the black evo 9 that won its class at last years event. i dont know what class it was in.
that would have had close to 6 figures thrown at it. even thoe it was mainly just bolt on stuff some one has to bolt the shit in and tune it ect ect.
i got to work on it when it landed in tassie and there was quite a few expensive bits on it.
a work shop down here biulds the latest model WRXs to tarmac or gravel trim using mainly sti and factory bits and with the purchase of the car it cost excess off 100 000 so i cant see how this evo with 2.4l big turbo e85 ect could be build much cheaper. but i ony work on nissans, and cheap nissans so i couldnt really say
either way looks like ill be making the trim up. ill start planning weather to come by plane or car.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
