  • 4 weeks later...
has anyone tried the Kando Dynamic TD06L2-20g 10cm rear on an rb25 yet?
I have an adapter to run an external gate on the stock manifold and i just want to hit 280rwkw, im thinking the L2 may fall short?
They are about $800 delivered from Kando, I am itching to buy one.
To note, the T67 wheel and 10cm housing OBVIOUSLY has no power restriction (ref Simons results) and results for the td06sl2-20g can be seen on more evos than you can poke a stick at.
Evos generally do not struggle to make 260AWKW from the said turbo on a 10.5cm rear housing and are generally on full song by 4500rpm with epic spool before that also.
The fastest evo I have driven had a td06sl2-20g 10.5cm and 272 cams, it would out rev the motor and had some serious pull from about the 3000rpm range, it had made 280AWKW on that setup and featured in a magazine. Others have made over 300awkw on these turbos with E85.
Might I add we have seen Roy get 260rwkw from an RB20 of all motors on one of these turbos, with VERY acceptable spool. An RB25 would possibly spool one of these better than your average highflow.
I have a feeling that we are fools for overlooking these turbos. I really am looking at grabing one for my 1J and having an all out balistic sub 300rwkw setup. The price of my turbo, manifold and gate will rival the cost of a garrett on its own.
Sorry for the Hijack Simon, Im going to put together a thread some time with links to your own results (for ref to the T67 rear and 10cm housing) along with evo results (for ref of the T67 combined with 20g front on a itty bitty 2L) very soon.
I have ordered a t67 to go with my 6boost and 44mm tial...
Came to this decision over the td06l2 cause of posts on a
Subaru forum where the concensuss was that the L2 was too small for the 2.5l boxer engine
See how I go if it's too laggy ill just swap on a td06l2
Thread is about Kando/Kinugawa/Kamak turbos not my results, so any results you have feel free to stick them up on here :)
The TD06SL2 is the same wheel as the T67 Simon is running.
The turbo you noted prior is the exact turbine wheel and exhaust housing.
Simon has made 410rwkw with it, no restriction.
Maybe the Subaru boys were refering to a different wheel, not the SL2.
Yeah the TD06SL2 has the same exhaust wheel and housing as a T67 but with 20g compressor and housing to suit. I would still think a T67 would be better on a RB25 and the SL2 for a RB20
410kw was a little bit of a piss take with correction on... More realistically it makes 390kw on a hub dyno and 360rwkw on a dyno dynamics roller :)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
