Even if it is too small you surely should be able to get it to hold flat boost with an appropriate boost controller setup if using an external gate?
That involves using an 'appropriately' sized wastegate more than it does a method of boost control.
Those sorts of setups DO work, like running a .63 rear end on a real 3076 (3037 56t). You can do it and it will make the power but in actual fact a good wastegate on such a setup is a bandaid fix for something that needs a bigger housing. Use of stuff like E85 is also good for ping resistance ETC, which is what you need when heat from the backed up exhaust housing makes its way into the cylinder.
Consider this: You can have a massive compressor on a tiny turbine, the turbine will accept X amount of flow to reach Y shaft speed. There is a V max for the compressor too, once Y surpases the Vmax of the compressor you are running outside of the compressor map. The big wastegate is bleeding off the motors flowpath to cap off the amount of exhaust gas hitting the turbine and increasing the shaft speed.
So the small exhaust housing makes you need less X to acheive Y, then you hit Xs maximum and X becomes a constant from the compressor side impacted by revs.
Anyway need to go home, enough theorising for one day.
NB 8cm housings work on SR20's which arent naturally big gulping motors.
I wouldn't say that. My mates gemmi put out 200 rwhp at only 12.5 psi. The engine is newly built and will be eventually be wound up to over 30 psi.
I can make 500kw with a megasquirt as well, doesn't mean it is a good ecu.
power != features OR a good software/hardware package
the fact is a microtech has a massive lack of features and shitty tuning software, it is a huge downgrade on a stock ecu with just simple remaps, using a nistune makes it infintely better than a microtech.
you can get them to work fine with air-con, i had one on my WRX in 1999 with a Gt30 etc , before they did flash tunes, I had one on my r31 with air-con, both drove like stock actually
a good tuner can get a decent result from them
cheers
darren
A good tuner can make anything work, eg a carby blow through setup, once again it doesn't make it a good setup. If you just stuck with the stock ecu and remapped it you'd have a much better solution, if you went nistune for $400 you'd be infinitely better off.
Why are you flogging a dead horse? i'm of to put nistune on my R31 so it idles like a concrete mixer..lol, because it has trouble even getting the smallest hydraulic cams to idle nice with big injectors on vl's or R31's.
When it comes to ECU's, some look crap on paper and in real life work, and some look great on paper and aren't that great, and despite what YOU might think, thats the way it is.....
cheers
darren
cheers
darren
Yes and microtech look crap on paper and work pretty average as well. Nistune etc have more features and also work much better.
You said it is a step backwards from a stock ecu. It isn't.
Hi guys.
I am writing to you from far away Russia.
I wanted to consult on the turbine .... I hope for your help .... here in Russia we can say qualified no ....
The car I Nissan Skyline R33 RB25det transmission mechanic 1995 release ...
All specs are great except for the turbine ........
In search of turbines ... saw this here
http://cgi.ebay.com/ebaymotors/Nissan-RB20-RB25DET-OBX-T67-25G-Turbo-Manifold-Combo-/160655839135?pt=Motors_Car_Truck_Parts_Accessories&hash=item2567d58f9f
What can you say about her??
Then I saw the turbine T67-25G Kinugawa ... and in search of information about her came across your forum .....
Friends please tell us all about this turbine ... Good?? Is not broken?? It is worth taking??
Ps
Read the whole subject is difficult for me because I own Angliskim bad language and a great chat through an interpreter translate the posts ... I'm sorry for my bad anglisky .... hope for your help
Specs my car:
Now stock turbo
Power FC+ comander ECU (lies at home)
Greddy intercooller
oil-cooller
Greddy Profec B Spec II
Exhaust Hks super drager + frontpipe
Z32 AFM (lies at home)
Apexi power intakeFilter
Fuel pump Nismo bnr-34
Fuel regulator Sard
LSD 2-way
sensors DEFI
Piston GT-R
ear ACL
and so on trifles
Edited by LINE26
Has been sitting there for weeks collecting dust, my fabricator dogged me, then he turned up 2 days ago and bent up the main roll cage hoop then left, now he lost part of his finger working on the lathe at his.
Im learning to tig at the moment so i can do my own alloy work. I have no issue's with a mig and mild/stainless.
He has modded the cooler so its a return flow, so all piping will be on the turbo side. He ordered all 3inch from memory even though thats not wat i wanted.
No harm in big cooler piping. More volume after the cooler will result in a denser charge and more oxygen in every gulp id say.
Hurry up and show me what that turbo can do lol
Hi guys.
http://cgi.ebay.com/...=item2567d58f9f
Ps
Answer somebody please
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
